i have the following error message in NC Admin Panel:
[PHP] Error: Error: Undefined offset: 3 at /usr/share/nextcloud/lib/private/legacy/OC_Helper.php#548 at <>
- /usr/share/nextcloud/lib/private/legacy/OC_Helper.php line 548
OC\Log\ErrorHandler::onError(8, “Undefined offset: 3”, “/usr/share/next … p”, 548, {path: “/”,rootI … }}) - /usr/share/nextcloud/apps/settings/lib/Settings/Personal/PersonalInfo.php line 108
OC_Helper::getStorageInfo("/") - /usr/share/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php line 141
OCA\Settings\Settings\Personal\PersonalInfo->getForm() - /usr/share/nextcloud/apps/settings/lib/Controller/PersonalSettingsController.php line 77
OCA\Settings\Controller\PersonalSettingsController->formatSettings({10: [OCA\Settin … ]}) - /usr/share/nextcloud/apps/settings/lib/Controller/CommonSettingsTrait.php line 152
OCA\Settings\Controller\PersonalSettingsController->getSettings(“personal-info”) - /usr/share/nextcloud/apps/settings/lib/Controller/PersonalSettingsController.php line 68
OCA\Settings\Controller\PersonalSettingsController->getIndexResponse(“personal”, “personal-info”) - /usr/share/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 169
OCA\Settings\Controller\PersonalSettingsController->index(“personal-info”) - /usr/share/nextcloud/lib/private/AppFramework/Http/Dispatcher.php line 100
OC\AppFramework\Http\Dispatcher->executeController(OCA\Settings\Con … {}, “index”) - /usr/share/nextcloud/lib/private/AppFramework/App.php line 152
OC\AppFramework\Http\Dispatcher->dispatch(OCA\Settings\Con … {}, “index”) - /usr/share/nextcloud/lib/private/Route/Router.php line 308
OC\AppFramework\App::main(“OCA\Settings\ … r”, “index”, OC\AppFramework\ … {}, {section: "perso … "}) - /usr/share/nextcloud/lib/base.php line 1009
OC\Route\Router->match("/settings/user") - /usr/share/nextcloud/index.php line 37
OC::handleRequest()
GET /index.php/settings/user
from 192.168.154.180 by admin at 2020-10-27T16:51:51+00:00
Regards
Uwe
