Hello! The 18.0 version of the Nextcloud is here. How to do the upgrade? Do you plan to do the upgrade and it will be available on updates section or we need to plan the manual upgrade? NethServer Version: 7.7.1908 Module: NextCloud 1.8.4 (17.02)
Thanks!
Who knows We need to study the manual and do some tests Would you try to do it and see if NC 18 can run on NethServer?
I hope so, but we will know only when the above tests are finished. We appreciate any help!
Hello if you need some testings . Next month is free ;-), so i like to try 18. But NS runs under XCP-NG.
