It also happens during package update from 0.1.3 to 0.1.5.
It would be appropriate for Nextcloud to increase the download timeout.
With the connections we have in Italy downloading from GUI always hangs! ![]()
Another thing NS users of the OO app should know.
https://github.com/nextcloud/documentserver_community/issues/12
It’s very broken, I’ve tested this on two installs and changes aren’t saved.
The iOS app login is broken.
I unshared a folder and everything shared with other users was unshared.
WTF is going on over there at NextCloud?
we are using 0.x.x en 18.0.0 releases what can we expect?
i personally think documentserver 0.5 will be grown up and 18.0.1 will be more stable.
i have created a issue on github to do a upgrade
solves the time-out issues
Good to know!
Would you mind opening also the related PR? Thanks! ![]()
yeah! ![]()
Opened
Now that nextcloud includes onlyoffice community pre-packaged.
i have seen a number of you folks complain that ist shallow.
considering that, do we still use the normal method of installing only office with nethserver, will it still work fine, or some things will break?
Everything should work fine.
NC 18.0.1 is ready to be tested @federico.ballarini @saitobenkei @jgelauff.
Please carefully ready the QA notes! ![]()
I don’t want to break my Enterprise installation ![]()
i have deployed a new test server, i am currently testing and tinkering.
I have not yet installed onlyoffice, or collabora yet to test.
seems there are now new very 9ice functions in the new ver+sion of nextcloud.
Hello did you use the 5.5. Doc Server ? without mobile ?
or a old one including mobile Use
NethServer Version: latest
Module: onlyoffice
When I try to install or remove onlyoffice repo, I get an error. later on, told nothing to do
then when I run yum -y install nethserver-onlyoffice i get the error package not available
i have tried to re-install, update, remove but every time I run into an error. how can I fix this issue.
when i run signal-event nethserver-onlyoffice-update
i get error
Can’t open directory /etc/e-smith/events/nethserver-onlyoffice-update
If you already installed the repo the following should work:
yum install nethserver-onlyoffice --enablerepo=mrmarkuz
Error getting repository data for mrmarkuz, repository not found
Did you install the repo?
yes, repo already installed
and now, just like magic it decided to work.
weired.
also, add this on the wiki.
You know that anyone can edit the wiki, right?
oh, forgot that part. thanks, will be updating
