Nextcloud 14 - Call for QA!
Nextcloud 14 is just in testing !
If you want to take part in the test, here are all the information on how to do it: https://github.com/NethServer/dev/issues/5578#issuecomment-420719518
Many improvements on:
Changes for developers: https://nextcloud.com/blog/changes-for-developers-in-nextcloud-14-beta-4-ready-for-testing/
If you want to see all related videos, take a look at nextcloud conference 2018: also Nethesis & NethServer was present with a “talk” on how easy is to have Nextcloud ready to use with 1-click installation using NethServer (here the video).
If you want to help us with the testing, you can also start from a NethServer virtualbox machine already created using vagrant.
  • To start from a clean NethServer 7.5.1804 machine, you can execute:
wget https://raw.githubusercontent.com/alepolidori/vagrant-files/master/nethserver-7.5.1804/Vagrantfile
vagrant up
more info here: https://app.vagrantup.com/ale_polidori/boxes/NethServer/versions/7.5.1804
  • To start from Nextcloud 13.0.6 with LDAP account provider, you can execute:
wget https://raw.githubusercontent.com/alepolidori/vagrant-files/master/nextcloud/nextcloud-13.0.6/Vagrantfile
vagrant up
more info here: https://app.vagrantup.com/ale_polidori/boxes/Nextcloud/versions/13.0.6
Tagging here @flatspin @m.traeumner @greavette @dnutan @dz00te
A lot of new things in this release, I love it
One thing I’ve noticed in (very brief) playing with it under FreeBSD is that occ complains if memory_limit is set to less than 512 MB.
Again for what is it worth : update worked on armhfp (32 bit)
See this on the RPI (arm), does it occur on a nethserver x86_64 too?
It worths a lot!
Thank you @dan and @mark_nl, it could be fixed https://github.com/NethServer/dev/issues/5578#issuecomment-421910870
Can you confirm us ?
Sorry, I don’t use virtualbox anymore.
I’ve set up a test VM with NC 13.0.6 joined to my AD. So as soon as you have something in testing-repo I’ll be able to help.
Nextcloud 14 has been released, thanks all for the excellent work!
Update to MC 14 works fine. Onlyoffice still works (selfsigned certs).
2 Warnings:
Not NS related, but some apps don’t work in NC14 after update.
In my case: draw.io and quick notes.
And Gpxpod must be updated manually.
So I revert back to NC 13.
Both of them are managed by the upgrade process.
Can you check your messages for some warning/errors ?
If you try again, you can also execute signal-event nethserver-nextcloud-update if the problem still be present
I already did a rollback to previous snpshot.
But I can do the update again and look, if it happens again.
Will give feedback later.
@flatspin if you want, also 14.0.1 has been released and it will be on QA ASAP.
The issue here.
Did the update again, but with no success:
When I ry to access NC I see this:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
More details can be found in the server log.
Tried to do
and
supervisorctl restart all
but with no success.
From messages.log:
Sep 26 13:50:33 colab-server sssd[be[jeckel.local]]: Backend is online
Sep 26 13:50:33 colab-server yum[2489]: Updated: nextcloud-14.0.0-1.el7.noarch
Sep 26 13:50:33 colab-server yum[2489]: Updated: nethserver-nextcloud-1.2.5-1.ns7.noarch
Sep 26 13:50:33 colab-server yum[2489]: Updated: nethserver-duc-1.4.5-1.ns7.noarch
Sep 26 13:50:34 colab-server sssd: tkey query failed: GSSAPI error: Major = Unspecified GSS failure.  Minor code may provide more information, Minor = Server not found in Kerberos database.
Sep 26 13:50:35 colab-server sssd: tkey query failed: GSSAPI error: Major = Unspecified GSS failure.  Minor code may provide more information, Minor = Server not found in Kerberos database.
Sep 26 13:50:38 colab-server esmith::event[2600]: Event: nethserver-duc-update
Sep 26 13:50:38 colab-server esmith::event[2600]: Action: /etc/e-smith/events/nethserver-duc-update/S20nethserver-duc-conf SUCCESS [0.004233]
Sep 26 13:50:38 colab-server esmith::event[2600]: Event: nethserver-duc-update SUCCESS
Sep 26 13:50:38 colab-server esmith::event[2603]: Event: nethserver-nextcloud-update
Sep 26 13:50:38 colab-server esmith::event[2603]: Migrating existing database configuration
Sep 26 13:50:38 colab-server dbus[749]: [system] Activating via systemd: service name='org.freedesktop.timedate1' unit='dbus-org.freedesktop.timedate1.service'
Sep 26 13:50:38 colab-server systemd: Starting Time & Date Service...
Sep 26 13:50:38 colab-server dbus[749]: [system] Successfully activated service 'org.freedesktop.timedate1'
Sep 26 13:50:38 colab-server systemd: Started Time & Date Service.
Sep 26 13:50:38 colab-server esmith::event[2603]: Migrating existing database certificates
Sep 26 13:50:38 colab-server esmith::event[2603]: Migrating existing database networks
Sep 26 13:50:39 colab-server esmith::event[2603]: Migrating existing database routes
Sep 26 13:50:39 colab-server esmith::event[2603]: Migrating existing database accounts
Sep 26 13:50:39 colab-server esmith::event[2603]: Migrating existing database proxypass
Sep 26 13:50:39 colab-server esmith::event[2603]: Migrating existing database dhcp
Sep 26 13:50:39 colab-server esmith::event[2603]: Migrating existing database hosts
Sep 26 13:50:39 colab-server esmith::event[2603]: Migrating existing database fwrules
Sep 26 13:50:39 colab-server esmith::event[2603]: Migrating existing database fwservices
Sep 26 13:50:39 colab-server esmith::event[2603]: Migrating existing database portforward
Sep 26 13:50:39 colab-server esmith::event[2603]: Migrating existing database tc
Sep 26 13:50:39 colab-server esmith::event[2603]: Action: /etc/e-smith/events/nethserver-nextcloud-update/S00initialize-default-databases SUCCESS [0.801817]
Sep 26 13:50:39 colab-server esmith::event[2603]: expanding /etc/httpd/conf.d/default-virtualhost.inc
Sep 26 13:50:39 colab-server esmith::event[2603]: expanding /etc/httpd/conf.d/nethserver.conf
Sep 26 13:50:39 colab-server esmith::event[2603]: expanding /etc/httpd/conf.d/nextcloud.conf
Sep 26 13:50:39 colab-server esmith::event[2603]: expanding /etc/httpd/conf.d/zz_nextcloud.conf
Sep 26 13:50:39 colab-server esmith::event[2603]: expanding /etc/opt/rh/rh-php71/php.d/20-opcache.ini
Sep 26 13:50:39 colab-server esmith::event[2603]: Action: /etc/e-smith/events/actions/generic_template_expand SUCCESS [0.396495]
Sep 26 13:50:41 colab-server esmith::event[2603]: Nextcloud or one of the apps require upgrade - only a limited number of commands are available
Sep 26 13:50:41 colab-server esmith::event[2603]: You may use your browser or the occ upgrade command to do the upgrade
Sep 26 13:50:41 colab-server esmith::event[2603]: Maintenance mode enabled
Sep 26 13:50:42 colab-server esmith::event[2603]: Nextcloud or one of the apps require upgrade - only a limited number of commands are available
Sep 26 13:50:42 colab-server esmith::event[2603]: You may use your browser or the occ upgrade command to do the upgrade
Sep 26 13:50:42 colab-server esmith::event[2603]: Set log level to debug
Sep 26 13:50:42 colab-server esmith::event[2603]: Updating database schema
Sep 26 13:50:45 colab-server esmith::event[2603]: Updated database
Sep 26 13:50:45 colab-server esmith::event[2603]: Disabled incompatible app: drawio
Sep 26 13:50:45 colab-server esmith::event[2603]: Disabled incompatible app: gpxpod
Sep 26 13:50:45 colab-server esmith::event[2603]: Disabled incompatible app: quicknotes
Sep 26 13:50:45 colab-server esmith::event[2603]: Updating <federatedfilesharing> ...
Sep 26 13:50:45 colab-server esmith::event[2603]: Updated <federatedfilesharing> to 1.4.0
Sep 26 13:50:45 colab-server esmith::event[2603]: Updating <files_pdfviewer> ...
Sep 26 13:50:45 colab-server esmith::event[2603]: Updated <files_pdfviewer> to 1.3.2
Sep 26 13:50:45 colab-server esmith::event[2603]: Updating <files_texteditor> ...
Sep 26 13:50:45 colab-server esmith::event[2603]: Updated <files_texteditor> to 2.6.0
Sep 26 13:50:45 colab-server esmith::event[2603]: Updating <files_videoplayer> ...
Sep 26 13:50:45 colab-server esmith::event[2603]: Updated <files_videoplayer> to 1.3.0
Sep 26 13:50:45 colab-server esmith::event[2603]: Updating <gallery> ...
Sep 26 13:50:45 colab-server esmith::event[2603]: Updated <gallery> to 18.1.0
Sep 26 13:50:45 colab-server esmith::event[2603]: Updating <password_policy> ...
Sep 26 13:50:45 colab-server esmith::event[2603]: Updated <password_policy> to 1.4.0
Sep 26 13:50:45 colab-server esmith::event[2603]: Updating <provisioning_api> ...
Sep 26 13:50:45 colab-server esmith::event[2603]: Updated <provisioning_api> to 1.4.0
Sep 26 13:50:45 colab-server esmith::event[2603]: Updating <serverinfo> ...
Sep 26 13:50:45 colab-server esmith::event[2603]: Updated <serverinfo> to 1.4.0
Sep 26 13:50:45 colab-server esmith::event[2603]: Updating <survey_client> ...
Sep 26 13:50:46 colab-server esmith::event[2603]: Updated <survey_client> to 1.2.0
Sep 26 13:50:46 colab-server esmith::event[2603]: Updating <twofactor_backupcodes> ...
Sep 26 13:50:46 colab-server esmith::event[2603]: Updated <twofactor_backupcodes> to 1.3.1
Sep 26 13:50:46 colab-server esmith::event[2603]: Updating <updatenotification> ...
Sep 26 13:50:46 colab-server esmith::event[2603]: Updated <updatenotification> to 1.4.1
Sep 26 13:50:46 colab-server esmith::event[2603]: Updating <federation> ...
Sep 26 13:50:46 colab-server esmith::event[2603]: Updated <federation> to 1.4.0
Sep 26 13:50:46 colab-server esmith::event[2603]: Updating <lookup_server_connector> ...
Sep 26 13:50:46 colab-server esmith::event[2603]: Updated <lookup_server_connector> to 1.2.0
Sep 26 13:50:46 colab-server esmith::event[2603]: Updating <oauth2> ...
Sep 26 13:50:46 colab-server esmith::event[2603]: Updated <oauth2> to 1.2.1
Sep 26 13:50:46 colab-server esmith::event[2603]: Updating <user_ldap> ...
Sep 26 13:50:46 colab-server esmith::event[2603]: Updated <user_ldap> to 1.4.0
Sep 26 13:50:46 colab-server esmith::event[2603]: Updating <files> ...
Sep 26 13:50:46 colab-server esmith::event[2603]: Updated <files> to 1.9.0
Sep 26 13:50:46 colab-server esmith::event[2603]: Updating <dav> ...
Sep 26 13:50:47 colab-server esmith::event[2603]: Fix broken values of calendar objects
Sep 26 13:50:47 colab-server esmith::event[2603]: Starting ...
Sep 26 13:50:47 colab-server esmith::event[2603]:    0/0 [>---------------------------]   0%
Sep 26 13:50:47 colab-server esmith::event[2603]: Updated <dav> to 1.6.0
Sep 26 13:50:47 colab-server esmith::event[2603]: Updating <files_sharing> ...
Sep 26 13:50:48 colab-server esmith::event[2603]: Updated <files_sharing> to 1.6.2
Sep 26 13:50:48 colab-server esmith::event[2603]: Updating <files_trashbin> ...
Sep 26 13:50:48 colab-server esmith::event[2603]: Updated <files_trashbin> to 1.4.1
Sep 26 13:50:48 colab-server esmith::event[2603]: Updating <files_versions> ...
Sep 26 13:50:48 colab-server esmith::event[2603]: Updated <files_versions> to 1.7.1
Sep 26 13:50:48 colab-server esmith::event[2603]: Updating <sharebymail> ...
Sep 26 13:50:48 colab-server esmith::event[2603]: Updated <sharebymail> to 1.4.0
Sep 26 13:50:48 colab-server esmith::event[2603]: Updating <workflowengine> ...
Sep 26 13:50:48 colab-server esmith::event[2603]: Updated <workflowengine> to 1.4.0
Sep 26 13:50:48 colab-server esmith::event[2603]: Updating <comments> ...
Sep 26 13:50:48 colab-server esmith::event[2603]: Updated <comments> to 1.4.0
Sep 26 13:50:48 colab-server esmith::event[2603]: Updating <firstrunwizard> ...
Sep 26 13:50:48 colab-server esmith::event[2603]: Updated <firstrunwizard> to 2.3.0
Sep 26 13:50:48 colab-server esmith::event[2603]: Updating <nextcloud_announcements> ...
Sep 26 13:50:48 colab-server esmith::event[2603]: Updated <nextcloud_announcements> to 1.3.0
Sep 26 13:50:49 colab-server esmith::event[2603]: Updating <notifications> ...
Sep 26 13:50:49 colab-server esmith::event[2603]: Updated <notifications> to 2.2.1
Sep 26 13:50:49 colab-server esmith::event[2603]: Updating <systemtags> ...
Sep 26 13:50:49 colab-server esmith::event[2603]: Updated <systemtags> to 1.4.0
Sep 26 13:50:49 colab-server esmith::event[2603]: Updating <theming> ...
Sep 26 13:50:49 colab-server esmith::event[2603]: Updated <theming> to 1.5.0
Sep 26 13:50:49 colab-server esmith::event[2603]: Checking for update of app calendar in appstore
Sep 26 13:50:50 colab-server esmith::event[2603]: Update app calendar from appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "calendar" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app cloud_federation_api in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "cloud_federation_api" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app comments in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "comments" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app dav in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "dav" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app federatedfilesharing in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "federatedfilesharing" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app federation in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "federation" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app files in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "files" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app files_pdfviewer in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "files_pdfviewer" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app files_sharing in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "files_sharing" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app files_texteditor in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "files_texteditor" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app files_trashbin in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "files_trashbin" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app files_versions in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "files_versions" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app files_videoplayer in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "files_videoplayer" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app firstrunwizard in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "firstrunwizard" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app gallery in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "gallery" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app logreader in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "logreader" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app lookup_server_connector in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checked for update of app "lookup_server_connector" in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Checking for update of app mail in appstore
Sep 26 13:50:54 colab-server esmith::event[2603]: Update app mail from appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Purify and migrate collected mail addresses
Sep 26 13:51:00 colab-server esmith::event[2603]: Starting ...
Sep 26 13:51:00 colab-server esmith::event[2603]:    0/0 [>---------------------------]   0%
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "mail" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app nextcloud_announcements in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "nextcloud_announcements" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app notes in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "notes" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app notifications in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "notifications" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app oauth2 in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "oauth2" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app onlyoffice in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "onlyoffice" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app password_policy in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "password_policy" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app provisioning_api in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "provisioning_api" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app serverinfo in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "serverinfo" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app sharebymail in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "sharebymail" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app survey_client in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "survey_client" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app systemtags in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "systemtags" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app tasks in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "tasks" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app theming in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "theming" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app twofactor_backupcodes in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "twofactor_backupcodes" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app updatenotification in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "updatenotification" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app user_ldap in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "user_ldap" in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checking for update of app workflowengine in appstore
Sep 26 13:51:00 colab-server esmith::event[2603]: Checked for update of app "workflowengine" in appstore
Sep 26 13:51:01 colab-server esmith::event[2603]: Starting code integrity check...
Sep 26 13:51:06 colab-server esmith::event[2603]: Finished code integrity check
Sep 26 13:51:06 colab-server esmith::event[2603]: Update successful
Sep 26 13:51:06 colab-server esmith::event[2603]: Maintenance mode is kept active
Sep 26 13:51:06 colab-server esmith::event[2603]: Reset log level
Sep 26 13:51:06 colab-server esmith::event[2603]: Maintenance mode disabled
Sep 26 13:51:08 colab-server esmith::event[2603]: Check indices of the share table.
Sep 26 13:51:09 colab-server esmith::event[2603]: Adding additional mtime index to the filecache table, this can take some time...
Sep 26 13:51:09 colab-server esmith::event[2603]: Filecache table updated successfully.
Sep 26 13:51:09 colab-server esmith::event[2603]: Action: /etc/e-smith/events/nethserver-nextcloud-update/S20nethserver-nextcloud-conf SUCCESS [29.757113]
Sep 26 13:51:09 colab-server su: (to apache) root on none
Sep 26 13:51:09 colab-server systemd: Created slice User Slice of apache.
Sep 26 13:51:09 colab-server systemd: Starting User Slice of apache.
Sep 26 13:51:09 colab-server systemd: Started Session c1 of user apache.
Sep 26 13:51:09 colab-server systemd: Starting Session c1 of user apache.
Sep 26 13:51:10 colab-server esmith::event[2603]: System config value trusted_domains => 0 set to string localhost
Sep 26 13:51:10 colab-server systemd: Removed slice User Slice of apache.
Sep 26 13:51:10 colab-server systemd: Stopping User Slice of apache.
Sep 26 13:51:10 colab-server su: (to apache) root on none
Sep 26 13:51:10 colab-server systemd: Created slice User Slice of apache.
Sep 26 13:51:10 colab-server systemd: Starting User Slice of apache.
Sep 26 13:51:10 colab-server systemd: Started Session c2 of user apache.
Sep 26 13:51:10 colab-server systemd: Starting Session c2 of user apache.
Sep 26 13:51:11 colab-server esmith::event[2603]: System config value trusted_domains => 1 set to string colab-server.jeckel.local
Sep 26 13:51:11 colab-server systemd: Removed slice User Slice of apache.
Sep 26 13:51:11 colab-server systemd: Stopping User Slice of apache.
Sep 26 13:51:11 colab-server su: (to apache) root on none
Sep 26 13:51:11 colab-server systemd: Created slice User Slice of apache.
Sep 26 13:51:11 colab-server systemd: Starting User Slice of apache.
Sep 26 13:51:11 colab-server systemd: Started Session c3 of user apache.
Sep 26 13:51:11 colab-server systemd: Starting Session c3 of user apache.
Sep 26 13:51:12 colab-server esmith::event[2603]: System config value memcache.local set to string \OC\Memcache\APCu
Sep 26 13:51:12 colab-server systemd: Removed slice User Slice of apache.
Sep 26 13:51:12 colab-server systemd: Stopping User Slice of apache.
Sep 26 13:51:12 colab-server su: (to apache) root on none
Sep 26 13:51:12 colab-server systemd: Created slice User Slice of apache.
Sep 26 13:51:12 colab-server systemd: Starting User Slice of apache.
Sep 26 13:51:12 colab-server systemd: Started Session c4 of user apache.
Sep 26 13:51:12 colab-server systemd: Starting Session c4 of user apache.
Sep 26 13:51:12 colab-server esmith::event[2603]: System config value logfile set to string /var/lib/nethserver/nextcloud/nextcloud.log
Sep 26 13:51:12 colab-server systemd: Started Session c5 of user apache.
Sep 26 13:51:12 colab-server systemd: Starting Session c5 of user apache.
Sep 26 13:51:13 colab-server esmith::event[2603]: System config value mail_smtpmode set to string smtp
Sep 26 13:51:13 colab-server systemd: Removed slice User Slice of apache.
Sep 26 13:51:13 colab-server systemd: Stopping User Slice of apache.
Sep 26 13:51:13 colab-server su: (to apache) root on none
Sep 26 13:51:13 colab-server systemd: Created slice User Slice of apache.
Sep 26 13:51:13 colab-server systemd: Starting User Slice of apache.
Sep 26 13:51:13 colab-server systemd: Started Session c6 of user apache.
Sep 26 13:51:13 colab-server systemd: Starting Session c6 of user apache.
Sep 26 13:51:14 colab-server esmith::event[2603]: System config value mail_smtpsecure set to empty string
Sep 26 13:51:14 colab-server systemd: Removed slice User Slice of apache.
Sep 26 13:51:14 colab-server systemd: Stopping User Slice of apache.
Sep 26 13:51:14 colab-server su: (to apache) root on none
Sep 26 13:51:14 colab-server systemd: Created slice User Slice of apache.
Sep 26 13:51:14 colab-server systemd: Starting User Slice of apache.
Sep 26 13:51:14 colab-server systemd: Started Session c7 of user apache.
Sep 26 13:51:14 colab-server systemd: Starting Session c7 of user apache.
Sep 26 13:51:15 colab-server esmith::event[2603]: System config value mail_smtpauthtype set to string LOGIN
Sep 26 13:51:15 colab-server systemd: Removed slice User Slice of apache.
Sep 26 13:51:15 colab-server systemd: Stopping User Slice of apache.
Sep 26 13:51:15 colab-server su: (to apache) root on none
Sep 26 13:51:15 colab-server systemd: Created slice User Slice of apache.
Sep 26 13:51:15 colab-server systemd: Starting User Slice of apache.
Sep 26 13:51:15 colab-server systemd: Started Session c8 of user apache.
Sep 26 13:51:15 colab-server systemd: Starting Session c8 of user apache.
Sep 26 13:51:15 colab-server esmith::event[2603]: System config value mail_from_address set to string no-reply
Sep 26 13:51:15 colab-server systemd: Started Session c9 of user apache.
Sep 26 13:51:15 colab-server systemd: Starting Session c9 of user apache.
Sep 26 13:51:16 colab-server esmith::event[2603]: System config value mail_domain set to string jeckel.local
Sep 26 13:51:16 colab-server systemd: Removed slice User Slice of apache.
Sep 26 13:51:16 colab-server systemd: Stopping User Slice of apache.
Sep 26 13:51:16 colab-server su: (to apache) root on none
Sep 26 13:51:16 colab-server systemd: Created slice User Slice of apache.
Sep 26 13:51:16 colab-server systemd: Starting User Slice of apache.
Sep 26 13:51:16 colab-server systemd: Started Session c10 of user apache.
Sep 26 13:51:16 colab-server systemd: Starting Session c10 of user apache.
Sep 26 13:51:17 colab-server esmith::event[2603]: System config value mail_smtphost set to string localhost
Sep 26 13:51:17 colab-server systemd: Removed slice User Slice of apache.
Sep 26 13:51:17 colab-server systemd: Stopping User Slice of apache.
Sep 26 13:51:17 colab-server su: (to apache) root on none
Sep 26 13:51:17 colab-server systemd: Created slice User Slice of apache.
Sep 26 13:51:17 colab-server systemd: Starting User Slice of apache.
Sep 26 13:51:17 colab-server systemd: Started Session c11 of user apache.
Sep 26 13:51:17 colab-server systemd: Starting Session c11 of user apache.
Sep 26 13:51:18 colab-server esmith::event[2603]: System config value mail_smtpport set to string 25
Sep 26 13:51:18 colab-server systemd: Removed slice User Slice of apache.
Sep 26 13:51:18 colab-server systemd: Stopping User Slice of apache.
Sep 26 13:51:18 colab-server su: (to apache) root on none
Sep 26 13:51:18 colab-server systemd: Created slice User Slice of apache.
Sep 26 13:51:18 colab-server systemd: Starting User Slice of apache.
Sep 26 13:51:18 colab-server systemd: Started Session c12 of user apache.
Sep 26 13:51:18 colab-server systemd: Starting Session c12 of user apache.
Sep 26 13:51:18 colab-server esmith::event[2603]: System config value trusted_domains => 2 set to string 192.168.0.237
Sep 26 13:51:18 colab-server systemd: Started Session c13 of user apache.
Sep 26 13:51:18 colab-server systemd: Starting Session c13 of user apache.
Sep 26 13:51:19 colab-server systemd: Removed slice User Slice of apache.
Sep 26 13:51:19 colab-server systemd: Stopping User Slice of apache.
Sep 26 13:51:19 colab-server su: (to apache) root on none
Sep 26 13:51:19 colab-server systemd: Created slice User Slice of apache.
Sep 26 13:51:19 colab-server systemd: Starting User Slice of apache.
Sep 26 13:51:19 colab-server systemd: Started Session c14 of user apache.
Sep 26 13:51:19 colab-server systemd: Starting Session c14 of user apache.
Sep 26 13:51:20 colab-server systemd: Removed slice User Slice of apache.
Sep 26 13:51:20 colab-server systemd: Stopping User Slice of apache.
I have the same problem as flatspin (internal server error and so on) ; the upgrade from nextcloud 13 to nextcloud 14 broke it.
httpd and slapd are up, i use the latest Nethserver version. The other services installed on my server (mail, SOGo and so on) work fine.
The logs don’t give me a clue of what is happening : /var/lib/nethserver/nextcloud/nextcloud.log
It sounds like this bug report : Nextcloud 13 - Call for QA! but i can’t log in as administrator.
Any idea ? Thanks.
Stef
Please report the real error, otherwise we can’t give any help.
Some files to check:
  • /var/opt/rh/rh-php71/log/php-fpm/error.log
  • /var/lib/nethserver/nextcloud/nextcloud.log
  • /var/log/httpd/ssl_error_log
  • /var/log/httpd/error_log
Hi stephane,
can you please try this:
login with admin and standardpassword: Nethesis,1234
go to settings in NC (right upper corner)
then to LDAP/AD Integration
In my case the Config showed red “config not o.k.”
(In this case: when you try to go to Users in admin menu you 'll get the internel server error, also when you try to login with a user from AD.)
I pressed the detect-port-button (right next to the port)
Then the config suddenly changed to green “config o.k.”
Now my NC 14.0.1 seems to work.
I can see the users in admin panel and login with AD-users.
Hi flatspin,
I solved the problem too, but it wasn’t a LDAP/AD error.
Usually, i upgrade nextcloud using either Firefox or Chromium ; in both cases, i got the same error as you. After uninstalling and reinstalling ‘nethserver-nextcloud’ and ‘nextcloud’, i tried to upgrade using Midori browser which changed everything : then, nextcloud got in maintenance mode. I disabled the maintenance mode using : sudo -u apache /opt/rh/rh-php71/root/usr/bin/php /usr/share/nextcloud/occ maintenance:mode --off
At that point, i changed my point of view and decided to upgrade using the cli interface. So a new uninstall/reinstall later, i tried : sudo -u apache /opt/rh/rh-php71/root/usr/bin/php /usr/share/nextcloud/occ upgrade and it worked :slight_smile:
Nextcloud 14 is up and running.
Thanks.
By the way, even if i’m not a dev, i checked the logs related in giacomo’s post but didn’t find anything really meaningful.
And many thanks to Marc who wrote : https://wiki.nethserver.org/doku.php?id=howto:nextcloud
Bye,
Stef
