Good afternoon,
Could you tell me how to change where the NextCloud data is stored after it is installed? I don’t finish scheduling the directories regarding the official version of NextCloud.
Thanks greetings!
Good afternoon,
Thanks greetings!
Nextcloud uses a mysql (mariadb) database to store data.
However, it is possible to mount an external storage in your nextcloud userinterface.
https://docs.nextcloud.com/server/stable/admin_manual/configuration_files/external_storage_configuration_gui.html
/var/lib/nethserver/nextcloud
Why did I think it was a database?.. silly me…
anyway. I found some more info on the path for nextcloud data:
