In these days I have installed an Enterprise nethserver and with the Markuz procedure the onlyoffice, as already many other times.
In the laboratory, to test, I installed and used the IP of the Lan with the commands to accept self-signed certificates and precisely the IP of the LAN.
In the past this procedure has always worked, now it doesn’t.
So, I did the same installation on a nethserver comunity installed some time ago and the procedure worked. At first glance the difference between the two machines is the version of nextcloud, this Saturday.
Today I tried again and even the old machine no longer works, so I don’t think it’s a nextcloud version problem. On both machines if I browse https://myiplan:8082, I can see the document server page correctly.
When I go in Nextcloud/config/Onlyoffice and push SAVE button in both servers, this is the result:
Sorry,
unfortunately I am not able to replicate the page in English.
I changed the language of the nethserver.
I changed the language to the nextcloud admin.
But I always see the onlyoffice configuration page in Italian …
Anyway I can attach the error log and that is in English …
TK
|Error|onlyoffice|Exception: An error has occurred in the document service: Invalid token
/usr/share/nextcloud/apps/onlyoffice/lib/documentservice.php - line 302:OCA\Onlyoffice\DocumentService->ProcessCommandServResponceError(6)
/usr/share/nextcloud/apps/onlyoffice/lib/documentservice.php - line 408:OCA\Onlyoffice\DocumentService->CommandRequest(“version”)
/usr/share/nextcloud/apps/onlyoffice/controller/settingscontroller.php - line 172:OCA\Onlyoffice\DocumentService->checkDocServiceUrl(OC\URLGenerator {}, OCA\Onlyoffice\Crypt {})
/usr/share/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 218:OCA\Onlyoffice\Controller\SettingsController->SaveAddress(“https://192.168.1.129:8082/”, “”, “”, true, “”, false)
/usr/share/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 127:OC\AppFramework\Http\Dispatcher->executeController(OCA\Onlyoffi … {}, “saveAddress”)
/usr/share/nextcloud/lib/private/AppFramework/App.php - line 157:OC\AppFramework\Http\Dispatcher->dispatch(OCA\Onlyoffi … {}, “saveAddress”)
/usr/share/nextcloud/lib/private/Route/Router.php - line 302:OC\AppFramework\App::main(“SettingsController”, “saveAddress”, OC\AppFramew … {}, { _route: "o … "})
/usr/share/nextcloud/lib/base.php - line 993:OC\Route\Router->match("/apps/onlyo … s")
/usr/share/nextcloud/index.php - line 37:OC::handleRequest()|
In the past I have installed many times from your how-to and the onlyoffice connector installed itself automatically with the password already entered.
Why, when I did the installation from your HowTo, the ONLYOFFICE connector did not install itself automatically as it always did in the past.
I had to instal manualy the connector and the password field was blank.
Is there any known reason?
TK
I could reproduce the issue.
With the recent Nextcloud version one can just type occ instead of the long version sudo -u apache /opt/rh/rh-php73/root/usr/bin/php -d memory_limit=512M /usr/share/nextcloud/occ
For the long version to work it would need --define apc.enable_cli=1 but just using occ is the right method.
In /etc/e-smith/events/actions/nethserver-onlyoffice-conf you may replace the 4 occ lines
