That was the ticket, thank you.
The info is right here:
http://docs.nethserver.org/en/v7b/nextcloud.html#installation
Sorry, I thought it was clear enough
How can I improve it?
Nope, you were fine. I was page blind focused on the thought that it was hosting Nextcloud on a different port rather then a subdirectory.
New major release 10.0.0 is available.
Some new features are:
- control workflow
- monitoring
- two Factor Authentication
- user interface enhancements
More information: https://nextcloud.com/secure-monitor-and-control-your-data-with-nextcloud-10-get-it-now
Do you have tried to upgrade? Is it flawless enough?
Good question
In my experience, I’ve upgraded an installation on my virtual machine to 10.0.0 and the only side effect I’ve experimented was that some apps (mail, chat, calendar and contact) have been disabled.
I easily re-enabled the apps without losing any configurations.
I think this is only because it is a major update and because the app store is a beta.
@alefattorini, could be interesting to know what features/apps are most used/useful ?
Would you like to enable/disable them by default? Honestly, I don’t know.
The Best feature is its on NS 7.
But as @alep mentioned, the most common ones used are mail, chat, calender and contacts. There are extras, but It really depends on the user themself
9 posts were split to a new topic: Fail2ban on NextCloud
