I like to open a little talk about networking and netshserver.
Actually I have HP gen10 with 2 lan
- One LAN is connected as green for internal network
- There is a bridge created automagically by the sistem for AD
-The other LAN is unused at the moment
I have all WINDOWS/LINUX client under the same network 192.168.X.Y/24
I have added the NETHSERVER as 192.168.X.11 (wuebui and shared folder) 192.168.X.10 (AD)
I have a the main ROUTER as 192.168.X.1 it has DHCP (from 192.168.X.100 to 192.168.X.250)- VPN(a lot) site to site and it connect to main internet router under ip space 192.168.Z.W/24
I know that using AD we have to set nethserver bridge interface as DNS resolver. This is a problem because WINDOWS become crazy and can’t resolve any internet address.
So at the moment a light and fast solution is to set the 8.8.8.8 as primary dns and nethserver as secondary. I have to inspect better with dns inpection tool.
But…
what is the idea behind nethserver netwokink.
DNS if configured is under green real interface 192.168.X.11 and bridge 192.168.X.10 has only the resolution for AD server name.
If I set the the default DNS as gereen interface and add inside neth a resolution rule for AD to the bridge ip and other to be forwareded to my default router, is this possible? is it a nice idea or open to a lot of problems?
