Network-recovery is not working?
Good afternoon. I moved the ssd from netserver to another server. It took a long time to load and gave out.
java_2021-11-12_14-34-55
I entered and typed “network-recovery” and set another ip
java_2021-11-12_14-37-51
But I can’t log in to the specified addresses.
Hi @kelevra,
I used several times the Network Recovery tool, without any issue.
Are you wililng to share a bit more about the “old server” and the “new server” hardware?
Your nethserver installation how many adapters/zones have?
Old Supermicro X8STi 8 x Intel(R) Xeon(R) CPU X5570 @ 2.93GHz
New Supermicro X9DRD-IF Intel Xeon E5-2670 v2
Yes, there are only 2 zones red and green, it worked as a gateway
Sorry, by accident
I’m italian, i cannot read russian, I’m sorry.
English version is much more readable to me :wink:
Did you checked on both network cards for the recovery/temporary address?
Yes, but it is reinstalled only on eno1, judging by the MAC
The network is working, ping is there, but services, including ssh, do not work. When trying to start the services, it goes into reboot.
