Of course,
[root@xpserver ~]# rpm -qa nethserver-*
nethserver-rh-php56-php-fpm-1.0.0-1.ns7.noarch
nethserver-hosts-1.2.1-1.ns7.noarch
nethserver-pulledpork-2.1.1-1.ns7.noarch
nethserver-dc-1.3.2-1.ns7.x86_64
nethserver-duc-1.4.3-1.ns7.noarch
nethserver-lightsquid-1.1.2-1.ns7.noarch
nethserver-backup-data-1.3.2-1.ns7.noarch
nethserver-ibays-3.1.1-1.ns7.noarch
nethserver-base-3.1.1-1.ns7.noarch
nethserver-dnsmasq-1.6.5-1.ns7.noarch
nethserver-openssh-1.2.1-1.ns7.noarch
nethserver-nethforge-release-7-0.3.ns7.noarch
nethserver-evebox-1.0.0-1.ns7.noarch
nethserver-yum-1.4.1-1.ns7.noarch
nethserver-php-1.2.0-1.ns7.noarch
nethserver-smartd-1.1.0-1.ns7.noarch
nethserver-ntopng-2.0.1-1.ns7.noarch
nethserver-lang-en-1.2.3-1.ns7.noarch
nethserver-release-7-5.ns7.noarch
nethserver-lang-pt-1.2.3-1.ns7.noarch
nethserver-squid-1.7.0-1.ns7.noarch
nethserver-c-icap-1.1.0-1.ns7.noarch
nethserver-squidclamav-3.0.0-1.ns7.noarch
nethserver-samba-2.0.10-1.ns7.noarch
nethserver-backup-config-2.0.3-1.ns7.noarch
nethserver-ntp-1.1.3-1.ns7.noarch
nethserver-httpd-3.1.4-1.ns7.noarch
nethserver-letsencrypt-1.1.4-1.ns7.noarch
nethserver-lib-2.2.6-1.ns7.noarch
nethserver-sssd-1.3.3-1.ns7.noarch
nethserver-antivirus-1.2.1-1.ns7.noarch
nethserver-firewall-base-ui-3.2.9-1.ns7.noarch
nethserver-mysql-1.1.3-1.ns7.noarch
nethserver-lsm-1.2.3-1.ns7.noarch
nethserver-net-snmp-1.1.0-1.ns7.noarch
nethserver-restore-data-1.2.3-1.ns7.noarch
nethserver-firewall-base-3.2.9-1.ns7.noarch
nethserver-phonehome-1.2.1-1.ns7.noarch
nethserver-mail-smarthost-1.0.0-1.ns7.noarch
nethserver-squidguard-1.7.4-1.ns7.noarch
nethserver-suricata-1.1.1-1.ns7.noarch
nethserver-httpd-admin-2.0.14-1.ns7.noarch
[root@xpserver ~]# db networks show
br0=bridge
bootproto=none
gateway=192.168.0.200
ipaddr=192.168.0.13
netmask=255.255.255.0
role=green
enp0s20u1=ethernet
FwInBandwidth=
FwOutBandwidth=
role=
enp2s0=ethernet
FwInBandwidth=
FwOutBandwidth=
bootproto=none
bridge=br0
role=bridged
Probably the problem is here, but I’m not sure exactly what file to modify this setting
[root@xpserver ~]# config show sssd
sssd=service
AdDns=192.168.2.2
LdapURI=
Provider=ad
Realm=AD.ABPOL.NET
Workgroup=ABPOL
status=enabled
[root@xpserver ~]# config show nsdc
nsdc=service
IpAddress=192.168.2.2
ProvisionType=newdomain
bridge=br0
status=enabled
[root@xpserver ~]# tail -n50 /var/log/messages
Mar 27 17:01:31 xpserver kill: -l, --list [=] list signal names, or convert one to a name
Mar 27 17:01:31 xpserver kill: -L, --table list signal names and numbers
Mar 27 17:01:31 xpserver kill: -h, --help display this help and exit
Mar 27 17:01:31 xpserver kill: -V, --version output version information and exit
Mar 27 17:01:31 xpserver kill: For more details see kill(1).
Mar 27 17:01:31 xpserver systemd: zabbix-agent.service: control process exited, code=exited status=1
Mar 27 17:01:31 xpserver systemd: Unit zabbix-agent.service entered failed state.
Mar 27 17:01:31 xpserver systemd: zabbix-agent.service failed.
Mar 27 17:01:41 xpserver systemd: zabbix-agent.service holdoff time over, scheduling restart.
Mar 27 17:01:41 xpserver systemd: Starting Zabbix Agent…
Mar 27 17:01:41 xpserver systemd: zabbix-agent.service: Supervising process 9201 which is not our child. We’ll most likely not notice when it exits.
Mar 27 17:01:41 xpserver systemd: Started Zabbix Agent.
Mar 27 17:01:41 xpserver systemd: zabbix-agent.service: main process exited, code=exited, status=1/FAILURE
Mar 27 17:01:41 xpserver kill: Usage:
Mar 27 17:01:41 xpserver kill: kill [options] <pid|name> […]
Mar 27 17:01:41 xpserver kill: Options:
Mar 27 17:01:41 xpserver kill: -a, --all do not restrict the name-to-pid conversion to processes
Mar 27 17:01:41 xpserver kill: with the same uid as the present process
Mar 27 17:01:41 xpserver kill: -s, --signal send specified signal
Mar 27 17:01:41 xpserver kill: -q, --queue use sigqueue(2) rather than kill(2)
Mar 27 17:01:41 xpserver kill: -p, --pid print pids without signaling them
Mar 27 17:01:41 xpserver kill: -l, --list [=] list signal names, or convert one to a name
Mar 27 17:01:41 xpserver kill: -L, --table list signal names and numbers
Mar 27 17:01:41 xpserver kill: -h, --help display this help and exit
Mar 27 17:01:41 xpserver kill: -V, --version output version information and exit
Mar 27 17:01:41 xpserver kill: For more details see kill(1).
Mar 27 17:01:41 xpserver systemd: zabbix-agent.service: control process exited, code=exited status=1
Mar 27 17:01:41 xpserver systemd: Unit zabbix-agent.service entered failed state.
Mar 27 17:01:41 xpserver systemd: zabbix-agent.service failed.
Mar 27 17:01:52 xpserver systemd: zabbix-agent.service holdoff time over, scheduling restart.
Mar 27 17:01:52 xpserver systemd: Starting Zabbix Agent…
Mar 27 17:01:52 xpserver systemd: zabbix-agent.service: Supervising process 9209 which is not our child. We’ll most likely not notice when it exits.
Mar 27 17:01:52 xpserver systemd: Started Zabbix Agent.
Mar 27 17:01:52 xpserver systemd: zabbix-agent.service: main process exited, code=exited, status=1/FAILURE
Mar 27 17:01:52 xpserver kill: Usage:
Mar 27 17:01:52 xpserver kill: kill [options] <pid|name> […]
Mar 27 17:01:52 xpserver kill: Options:
Mar 27 17:01:52 xpserver kill: -a, --all do not restrict the name-to-pid conversion to processes
Mar 27 17:01:52 xpserver kill: with the same uid as the present process
Mar 27 17:01:52 xpserver kill: -s, --signal send specified signal
Mar 27 17:01:52 xpserver kill: -q, --queue use sigqueue(2) rather than kill(2)
Mar 27 17:01:52 xpserver kill: -p, --pid print pids without signaling them
Mar 27 17:01:52 xpserver kill: -l, --list [=] list signal names, or convert one to a name
Mar 27 17:01:52 xpserver systemd: zabbix-agent.service: control process exited, code=exited status=1
Mar 27 17:01:52 xpserver kill: -L, --table list signal names and numbers
Mar 27 17:01:52 xpserver kill: -h, --help display this help and exit
Mar 27 17:01:52 xpserver kill: -V, --version output version information and exit
Mar 27 17:01:52 xpserver kill: For more details see kill(1).
Mar 27 17:01:52 xpserver systemd: Unit zabbix-agent.service entered failed state.
Mar 27 17:01:52 xpserver systemd: zabbix-agent.service failed.
