Thanks,
this helped me … I only created A-record for pbx and cti - today I created A-record for voice…
Then I configured nethvoice, but there is a error message:
<4>agent.ldapproxy: domain firma.lan should not be used by nethvoice1. Invoke agent.bind_user_domains(["firma.lan"]) to fix this warning.
Job for mariadb.service failed because the control process exited with error code.
See "systemctl --user status mariadb.service" and "journalctl --user -xeu mariadb.service" for details.
…There is the next trap. On debian terminal I get this:
systemctl --user status mariadb.service" and "journalctl --user mariadb.service
Failed to connect to bus: Die Operation ist nicht erlaubt
root@pbx:/home/tux# systemctl --user status mariadb.service
root@pbx:/home/tux# journalctl --user -xeu mariadb.service
No journal files were found.
I have to walk into another environment of this NS8 system …
How to do this ??
root@pbx:/home/nethvoice1# runagent -m nethvoice1
The job identifier is 1192 and the job result is done.
Feb 18 14:27:13 pbx systemd[750]: mariadb.service: Start request repeated too quickly.
Feb 18 14:27:13 pbx systemd[750]: mariadb.service: Failed with result 'exit-code'.
░░ Subject: Unit failed
░░ Defined-By: systemd
░░ Support: https://www.debian.org/support
░░ The unit UNIT has entered the 'failed' state with result 'exit-code'.
Feb 18 14:27:13 pbx systemd[750]: Failed to start mariadb.service - mariadb server.
░░ Subject: A start job for unit UNIT has failed
░░ A start job for unit UNIT has finished with a failure.
░░ The job identifier is 1192 and the job result is failed.
there is a problem with mariadb … but what can I do, to resolve this ??
The system protocol of NS8 said to me:
2025-02-18T15:11:28+01:00 [1:nethvoice1:systemd] Queued start job for default target default.target.
2025-02-18T15:11:28+01:00 [1:nethvoice1:systemd] Created slice app.slice - User Application Slice.
2025-02-18T15:11:28+01:00 [1:nethvoice1:systemd] Reached target paths.target - Paths.
2025-02-18T15:11:28+01:00 [1:nethvoice1:systemd] Reached target timers.target - Timers.
2025-02-18T15:11:28+01:00 [1:nethvoice1:systemd] Starting dbus.socket - D-Bus User Message Bus Socket...
2025-02-18T15:11:28+01:00 [1:nethvoice1:systemd] Listening on dirmngr.socket - GnuPG network certificate management daemon.
2025-02-18T15:11:28+01:00 [1:nethvoice1:systemd] Listening on gpg-agent-browser.socket - GnuPG cryptographic agent and passphrase cache (access for web browsers).
2025-02-18T15:11:28+01:00 [1:nethvoice1:systemd] Listening on gpg-agent-extra.socket - GnuPG cryptographic agent and passphrase cache (restricted).
2025-02-18T15:11:28+01:00 [1:nethvoice1:systemd] Listening on gpg-agent-ssh.socket - GnuPG cryptographic agent (ssh-agent emulation).
2025-02-18T15:11:28+01:00 [1:nethvoice1:systemd] Listening on gpg-agent.socket - GnuPG cryptographic agent and passphrase cache.
2025-02-18T15:11:28+01:00 [1:nethvoice1:systemd] Listening on dbus.socket - D-Bus User Message Bus Socket.
2025-02-18T15:11:28+01:00 [1:nethvoice1:systemd] Reached target sockets.target - Sockets.
2025-02-18T15:11:28+01:00 [1:nethvoice1:systemd] Reached target basic.target - Basic System.
2025-02-18T15:11:28+01:00 [1:nethvoice1:systemd] Started agent.service - Rootless module/nethvoice1 agent.
2025-02-18T15:11:28+01:00 [1:nethvoice1:systemd] Starting mariadb.service - mariadb server...
2025-02-18T15:11:28+01:00 [1:nethvoice1:podman] 2025-02-18 15:11:28.493018286 +0100 CET m=+0.138934711 system refresh
2025-02-18T15:11:28+01:00 [1:nethvoice1:podman] 2025-02-18 15:11:28.493589891 +0100 CET m=+0.139506307 image pull ghcr.io/nethesis/nethvoice-mariadb:1.1.3
2025-02-18T15:11:29+01:00 [1:nethvoice1:podman] Port mappings have been discarded as one of the Host, Container, Pod, and None network modes are in use
2025-02-18T15:11:29+01:00 [1:nethvoice1:podman] Error: running container create option: invalid timezone: is a directory
2025-02-18T15:11:29+01:00 [1:nethvoice1:systemd] Created slice session.slice - User Core Session Slice.
2025-02-18T15:11:29+01:00 [1:nethvoice1:systemd] Starting dbus.service - D-Bus User Message Bus...
2025-02-18T15:11:29+01:00 [1:nethvoice1:systemd] Started dbus.service - D-Bus User Message Bus.
2025-02-18T15:11:29+01:00 [1:nethvoice1:systemd] Created slice user.slice - Slice /user.
2025-02-18T15:11:29+01:00 [1:nethvoice1:systemd] Started podman-pause-3d44f89e.scope.
2025-02-18T15:11:29+01:00 [1:nethvoice1:systemd] mariadb.service: Control process exited, code=exited, status=125/n/a
2025-02-18T15:11:29+01:00 [1:nethvoice1:podman] Error: reading CIDFile: open /run/user/1006/mariadb.ctr-id: no such file or directory
2025-02-18T15:11:29+01:00 [1:nethvoice1:systemd] mariadb.service: Failed with result 'exit-code'.
2025-02-18T15:11:29+01:00 [1:nethvoice1:systemd] Failed to start mariadb.service - mariadb server.
2025-02-18T15:11:29+01:00 [1:nethvoice1:systemd] Reached target default.target - Main User Target.
2025-02-18T15:11:29+01:00 [1:nethvoice1:systemd] Startup finished in 1.654s.
2025-02-18T15:11:29+01:00 [1:nethvoice1:systemd] mariadb.service: Scheduled restart job, restart counter is at 1.
2025-02-18T15:11:29+01:00 [1:nethvoice1:systemd] Stopped mariadb.service - mariadb server.
2025-02-18T15:11:29+01:00 [1:nethvoice1:systemd] Starting mariadb.service - mariadb server...
2025-02-18T15:11:29+01:00 [1:nethvoice1:agent@nethvoice1] Handler of module/ldapproxy1/event/user-domain-changed is starting step 20configure_ldap
2025-02-18T15:11:29+01:00 [1:nethvoice1:podman] 2025-02-18 15:11:29.605368862 +0100 CET m=+0.050195614 image pull ghcr.io/nethesis/nethvoice-mariadb:1.1.3
2025-02-18T15:11:30+01:00 [1:nethvoice1:podman] Port mappings have been discarded as one of the Host, Container, Pod, and None network modes are in use
2025-02-18T15:11:30+01:00 [1:nethvoice1:podman] Error: running container create option: invalid timezone: is a directory
2025-02-18T15:11:30+01:00 [1:nethvoice1:systemd] mariadb.service: Control process exited, code=exited, status=125/n/a
2025-02-18T15:11:30+01:00 [1:nethvoice1:podman] Error: reading CIDFile: open /run/user/1006/mariadb.ctr-id: no such file or directory
2025-02-18T15:11:30+01:00 [1:nethvoice1:systemd] mariadb.service: Failed with result 'exit-code'.
2025-02-18T15:11:30+01:00 [1:nethvoice1:systemd] Failed to start mariadb.service - mariadb server.
2025-02-18T15:11:30+01:00 [1:nethvoice1:agent@nethvoice1] Traceback (most recent call last):
2025-02-18T15:11:30+01:00 [1:nethvoice1:agent@nethvoice1] File "/home/nethvoice1/.config/events/user-domain-changed/20configure_ldap", line 12, in <module>
2025-02-18T15:11:30+01:00 [1:nethvoice1:agent@nethvoice1] from ldapproxy import Ldapproxy
2025-02-18T15:11:30+01:00 [1:nethvoice1:agent@nethvoice1] ModuleNotFoundError: No module named 'ldapproxy'
2025-02-18T15:11:30+01:00 [1:nethvoice1:systemd] mariadb.service: Scheduled restart job, restart counter is at 2.
2025-02-18T15:11:30+01:00 [1:nethvoice1:systemd] Stopped mariadb.service - mariadb server.
2025-02-18T15:11:30+01:00 [1:nethvoice1:systemd] Starting mariadb.service - mariadb server...
2025-02-18T15:11:30+01:00 [1:nethvoice1:agent@nethvoice1] exit status 1
2025-02-18T15:11:30+01:00 [1:nethvoice1:agent@nethvoice1] Handler of module/ldapproxy1/event/user-domain-changed exited with status "aborted" (1) at step 20configure_ldap
2025-02-18T15:11:30+01:00 [1:nethvoice1:podman] 2025-02-18 15:11:30.664291547 +0100 CET m=+0.097785688 image pull ghcr.io/nethesis/nethvoice-mariadb:1.1.3
2025-02-18T15:11:31+01:00 [1:nethvoice1:podman] Port mappings have been discarded as one of the Host, Container, Pod, and None network modes are in use
2025-02-18T15:11:31+01:00 [1:nethvoice1:podman] Error: running container create option: invalid timezone: is a directory
2025-02-18T15:11:31+01:00 [1:nethvoice1:systemd] mariadb.service: Control process exited, code=exited, status=125/n/a
2025-02-18T15:11:31+01:00 [1:nethvoice1:podman] Error: reading CIDFile: open /run/user/1006/mariadb.ctr-id: no such file or directory
2025-02-18T15:11:31+01:00 [1:nethvoice1:systemd] mariadb.service: Failed with result 'exit-code'.
2025-02-18T15:11:31+01:00 [1:nethvoice1:systemd] Failed to start mariadb.service - mariadb server.
2025-02-18T15:11:31+01:00 [1:nethvoice1:systemd] mariadb.service: Scheduled restart job, restart counter is at 3.
2025-02-18T15:11:31+01:00 [1:nethvoice1:systemd] Stopped mariadb.service - mariadb server.
2025-02-18T15:11:31+01:00 [1:nethvoice1:systemd] Starting mariadb.service - mariadb server...
2025-02-18T15:11:32+01:00 [1:nethvoice1:podman] 2025-02-18 15:11:31.728207322 +0100 CET m=+0.079630188 image pull ghcr.io/nethesis/nethvoice-mariadb:1.1.3
2025-02-18T15:11:32+01:00 [1:nethvoice1:podman] Port mappings have been discarded as one of the Host, Container, Pod, and None network modes are in use
2025-02-18T15:11:32+01:00 [1:nethvoice1:podman] Error: running container create option: invalid timezone: is a directory
2025-02-18T15:11:32+01:00 [1:nethvoice1:systemd] mariadb.service: Control process exited, code=exited, status=125/n/a
2025-02-18T15:11:32+01:00 [1:nethvoice1:podman] Error: reading CIDFile: open /run/user/1006/mariadb.ctr-id: no such file or directory
2025-02-18T15:11:32+01:00 [1:nethvoice1:systemd] mariadb.service: Failed with result 'exit-code'.
2025-02-18T15:11:32+01:00 [1:nethvoice1:systemd] Failed to start mariadb.service - mariadb server.
2025-02-18T15:11:32+01:00 [1:nethvoice1:systemd] mariadb.service: Scheduled restart job, restart counter is at 4.
2025-02-18T15:11:32+01:00 [1:nethvoice1:systemd] Stopped mariadb.service - mariadb server.
2025-02-18T15:11:32+01:00 [1:nethvoice1:systemd] Starting mariadb.service - mariadb server...
2025-02-18T15:11:32+01:00 [1:nethvoice1:podman] 2025-02-18 15:11:32.63931692 +0100 CET m=+0.060826909 image pull ghcr.io/nethesis/nethvoice-mariadb:1.1.3
2025-02-18T15:11:33+01:00 [1:nethvoice1:podman] Error: reading CIDFile: open /run/user/1006/mariadb.ctr-id: no such file or directory
2025-02-18T15:11:33+01:00 [1:nethvoice1:systemd] mariadb.service: Control process exited, code=exited, status=125/n/a
2025-02-18T15:11:33+01:00 [1:nethvoice1:systemd] mariadb.service: Failed with result 'exit-code'.
2025-02-18T15:11:33+01:00 [1:nethvoice1:systemd] Failed to start mariadb.service - mariadb server.
2025-02-18T15:11:33+01:00 [1:nethvoice1:systemd] mariadb.service: Scheduled restart job, restart counter is at 5.
2025-02-18T15:11:33+01:00 [1:nethvoice1:systemd] Stopped mariadb.service - mariadb server.
2025-02-18T15:11:33+01:00 [1:nethvoice1:systemd] mariadb.service: Start request repeated too quickly.
2025-02-18T15:19:07+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/38d5585c-23d2-4aee-a75d-bd4972a32421: get-name/50get_name is starting
2025-02-18T15:19:07+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/d82411f0-6976-45ed-af0f-857369688414: get-status/20read is starting
2025-02-18T15:19:08+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/38d5585c-23d2-4aee-a75d-bd4972a32421: action "get-name" status is "completed" (0) at step 50get_name
2025-02-18T15:19:09+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/d82411f0-6976-45ed-af0f-857369688414: action "get-status" status is "completed" (0) at step validate-output.json
2025-02-18T15:19:12+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/f89a9b20-b878-475f-bd3b-f42194ec41bb: get-defaults/10defaults is starting
2025-02-18T15:19:12+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/fd44ce03-5ea0-4a39-8912-600e86a58a9f: get-rebranding/10read is starting
2025-02-18T15:19:12+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/f89a9b20-b878-475f-bd3b-f42194ec41bb: action "get-defaults" status is "completed" (0) at step validate-output.json
2025-02-18T15:19:12+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/dea3ab88-954e-4236-baed-3cfc9846ec8f: get-proxy-status/10get is starting
2025-02-18T15:19:13+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/fd44ce03-5ea0-4a39-8912-600e86a58a9f: action "get-rebranding" status is "completed" (0) at step validate-output.json
2025-02-18T15:19:13+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/aa6fe7f1-736c-4eca-96a5-09206fe6cf2e: get-configuration/20read is starting
2025-02-18T15:19:13+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/dea3ab88-954e-4236-baed-3cfc9846ec8f: action "get-proxy-status" status is "completed" (0) at step validate-output.json
2025-02-18T15:19:13+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/e8a64ac7-5bef-478a-9fd7-4cc04e77ab27: get-configuration/20read is starting
2025-02-18T15:19:13+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/aa92b822-f96c-46b8-95b5-3700ca0c4164: get-configuration/20read is starting
2025-02-18T15:19:13+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/aa6fe7f1-736c-4eca-96a5-09206fe6cf2e: action "get-configuration" status is "completed" (0) at step validate-output.json
2025-02-18T15:19:13+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/e8a64ac7-5bef-478a-9fd7-4cc04e77ab27: action "get-configuration" status is "completed" (0) at step validate-output.json
2025-02-18T15:19:13+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/aa92b822-f96c-46b8-95b5-3700ca0c4164: action "get-configuration" status is "completed" (0) at step validate-output.json
2025-02-18T15:19:48+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/fce5b2d5-aea8-49f4-a6ea-4e4c080c9352: get-status/20read is starting
2025-02-18T15:19:50+01:00 [1:nethvoice1:agent@nethvoice1] task/module/nethvoice1/fce5b2d5-aea8-49f4-a6ea-4e4c080c9352: action "get-status" status is "completed" (0) at step validate-output.json
It’s looking like a time zone error (?)
Did I something misunderstood in nethvoice configuration ??
Timezone
Europe
Request Let's Encrypt certificate
No
Reports Prefix
+49 ( i ) Format must be either "00**" or "+**"
Reset NethVoice admin password to access user interface (optional)
It is not possible to say “Timezone: Europe/Berlin” like other system do this.
That’s why I assume +49 is meant…
