NethServer Version: Nethserver 8 on Rocky 9.4
Module: Nethvoice and Nethvoice Proxy
Subscription: Enterprise linked on cluster.
Hi everyone.
Long time user of Nethesis. We have various Enterprise deploys and have been extremely happy.
I just launched my first Neth8 Nethvoice deploy and it might be cause I am used to dedicated VM and not containers but it is breaking my brains.
If someone can help me with a couple of points so I can get going on this. I am aware its still Beta but want to get jump on it.
- How do you login in to the container or module to run commands on it directly? I usually use asterisk -rvvvv to troubleshoot connections but it doesn’t exist on the leader. So how I get that to work?
- How do I upload my own custom sound files to the system? We have adjusted system languages that needs to be loaded.
- Might be a bug that still needs to be corrected but when I link a device to Nethvoice, I dont get the option to link that specific device to a User. On link device it only shows custom? Also when I add the device it just runs and nothing happens. When I refresh the device appears?
3.1) Where are logs stored for the above about provisioning and the services so I can track and see what is happening and why it hangs?
Thank you in advance!
