NethVoice certificates not removed with removal of NethVoice
as per title, I installed NethVoice-Proxy and NethVoice. Configured them both with FQDN as per config settings. Then I removed both NethVoice and NethVoice-Proxy, but the certificates are not removed and are visiable in settings → TLS Settings.
  1. Bug?
  2. Why are the certificates of NethVoice modules visable and the certificates of other modules not?
TIA
I could reproduce the issue. The NethVoice proxy certificate is still listed on the TLS certficates page.
I’m not sure if it’s a bug or a safer way to not automatically remove certs.
The cert can be deleted on the TLS cert page or via CLI:
api-cli run module/traefik1/delete-certificate --data '{"fqdn":"proxy.domain.tld","type":"internal"}'
AFAIK “webapp only” certificates are not listed on the TLS cert page.
Apps that use certificates also for other services than web are listed.
On the CLI had had to follow the order of cti.fqdn.ltd voice.fqdn.tld and then proxy.fqdn.tld
