NethServer virtualized with Proxmox
(Jan Jacobs) #1
After downloading the beta 6.6 iso i decided to give it a run on my Proxmox server.
At first i never could get the server to respond after setting the IP adress manually.
Asking the IRC channel one person seem to have had the same problem, but could not help me further.
In the end, setting the virtualized network to bridge mode (instead of NAT) has resolved all the issues!
I am now happily testing NethServer :slight_smile:
HowTo install NethServer on ProxMox OpenVZ container
NethServer on proxmox: no Internet connection
(Alessio Fattorini) #2
@lincee that’s a great hint! Can you add more details? We could write a generic FAQ or an howto to configure NethServer on Proxmox properly
(Jan Jacobs) #3
YES!
i can do so later :wink:
I’m kind of tied up now, but ill start the day after tomorrow
(Giacomo Sanchietti) #4
If you need simple virtual machine management, you could take a look to webvirtmgr:
http://docs.nethserver.org/en/latest/webvirtmgr.html
Just sayin’ :smile:
(Jan Jacobs) #5
Yes, for simple vm’s that could do the trick :wink:
But it makes no sense running a vm in a vm :wink:
(Giacomo Sanchietti) #6
Right…I just misunderstood what you wrote, my bad!
I though you were installing some parts of Proxmox on NethServer. :smile:
(Jan Jacobs) #7
That could actually be an idea :slight_smile:
(Alejandro Guerra) #8
hi @Lincee can u share your configuration?
Regards.
