Hello I have done some works on the mailling list sympa, we have to talk on it
yum install http://mirror.de-labrusse.fr/NethDev/nethserver-sympa/nethserver-sympa-0.0.2-1.ns7.noarch.rpm
I assume in the tutorial that domain.org is the first domain of your NethServer, domain2.org is the second domain
once installed the list admin manager is the user admin@domain.org, you need to install either samba AD or openldap, with sympa you need to use admin@domain.org (domain.org is the first domain registered)
once done you need to decide which domain email you want to use with sympa, you can add all domains you have on the server if the domain is not a relay and if the prop
SympaMaillingListis enabled (do it for each domain you want to enabled)db domains setprop domain.org SympaMaillingList enabled
signal-event nethserver-sympa-update -
once the domain is enabled, then go to the URL https://domain.org/sympa, login, request a first login (at the bottom) for the user admin@domain.org, an email is sent to the user admin to create his password. If you have several domain, you have to use the url of the domain
domain.org -> https://domain.org/sympa
domain2.org -> https://domain2.org/sympa
- once the password has been created you can create a list (top menu)
once the list created, generally I use Web forum mailing list Messages can either be read via email (subscription) or via the web (web archives) you need to change the default policy of email sending, default is summary (emails sent one day per week) , change it to direct (standard) (email received by the list , email forwarded)
then you can add members in the list directly, or if the list allow it users can directly subscribe themselves
The list of users display if the email is sent by summary or direct
Well you have plenty of settings, this is for expert and power admin, we can talk on it but like you I am discovering the tool. https://sympa-community.github.io/manual/admin.html
obviously :
you can have list@domain.org or list@domain2.org
I suppose that list@domain.org will break something if you had a user list@domain.org before
Other non users can request to create a list, I need to find how to disable this, if you know please ring the bell
My concern now is the custom-template I did, I need to talk on it, I removed virtual_alias_domains because I could not have the multi domain for sympa, the list@domain2.org was not found inside the virual table of postfix (it makes sense)
For what I tested (group@domain.org, user@wildcard, user@domain.org, user@domain2.org, public mailbox, all seems to work
