NethServer Version: 7.3
Module: SOGo
I have configured a local domain int.local and users 1234@int.local. I then created the additional mail domains ext.com and linked them to the users
1234@ext.com --> 1234@int.local
Since outlook via activesync with Sogo lets change the address of the sender i had to configure then /etc/postfix/generic to set up,
1234@int.local 1234@ext.com
However, I have noticed that the return-path address is
1234@int.local
How can I change it?
the problem via imap does not show up
regards
Andrea
I solved this by using this config option:
config setprop sogod IMAPLoginFieldName mail
signal-event nethserver-sogo-update
After that you need to set the AD mail property for the user-accounts, else it will not work. Shared mailboxes remain an issue in this scenario. This will only work with an AD as account provider afaik.
can u test this rpm
yum install http://mirror.de-labrusse.fr/NethDev/nethserver-sogo/nethserver-sogo-1.6.12-1.ns7.sdl.noarch.rpm
then all values ‘userPrincipalName’ will be changed to ‘mail’
for reversing
config setprop sogod IMAPLoginFieldName ''
or
config delprop sogod IMAPLoginFieldName
