For now, no clues. I know that thunderbird is working on a patch to decide whom send the email to attendees, sogo or thunderbird, but it will be a workaround.
…and is little good for EAX, the main reason for even using SOGo in my case.
It works perfectly with local ldap and local AD account provider.
There were problems with remote ldap, here is the remote sogo.log:
Nov 28 00:17:19 sogod [22875]: [ERROR] <0x0x556e2addcaf0[LDAPSource]> Could not bind to the LDAP server ldap://192.168.1.187:389 (389) using the bind DN: cn=ldapservice,dc=directory,dc=nh
Nov 28 00:17:19 sogod [22875]: [ERROR] <0x0x556e2addcaf0[LDAPSource]> <NSException: 0x556e2b298620> NAME:LDAPException REASON:operation bind failed: Invalid credentials (0x31) INFO:{"error_code" = 49; login = "cn=ldapservice,dc=directory,dc=nh"; }
Nov 28 00:17:19 sogod [22875]: <0x0x556e2b23ea60[LDAPSource]> <NSException: 0x556e2b0d02b0> NAME:LDAPException REASON:operation bind failed: Invalid credentials (0x31) INFO:{"error_code" = 49; login = "cn=markus,ou=groups,dc=directory,dc=nh"; }
Nov 28 00:17:19 sogod [22875]: SOGoRootPage Login from '192.168.1.115' for user 'markus' might not have worked - password policy: 65535 grace: -1 expire: -1 bound: 0
I had to change the 2 hostname lines in sogo.conf from
hostname = ldap://192.168.1.187:389;
to
hostname = ldaps://192.168.1.187;
to be able to login to sogo on remote ldap nethserver.
There were also problems with remote AD:
On my remote AD the servername/hostname was nethvm2.domain.local so joining to AD which is AD.CMB.LOCAL results in having markus@cmb.local on AD server and markus@domain.local on remote AD which may be a bug because it shouldn’t be possible to join nethvm2.domain.local to server.cmb.local. So I changed hostname to nethvm2.cmb.local, rejoined AD and it worked except of I had to change to ldaps (possible via web ui).
I know something with a remote samba AD
reference :
Cannot authenticate user with sogo and a remote AD
and
possibly it could be the same issue for a remote openldap. At least it seems so, I needed to change the url ldap to ldaps
for your issue on AD I will try to reproduce with the fix of @giacomo
well a remote openldap with anonymous or authenticated user for sogo are good, can you test again. Take care maybe to be with full updated VM
@giacomo I tested two times and for every time I have had a bind to the samba4AD (from another NS) with ldap and not ldaps.
Sogo cannot authentificate the user until I modify ldap to ldaps and I restart sogod
This is the automatic settings the wizard setup made
the bind is good of course
I tested again and it seems that if you enter a port on remote ldap bind, sogo won’t start because of bind does not work.
Trying it without a port
leads to
which is working perfectly.
But entering a port is fatal.
With port 636 I got
which leads to sogo not starting because of “segfault at 7ffd28961c18”. Sogo doesn’t like redundant port numbers.
and the following sogo.conf
/* 45 ldap authentication */
SOGoUserSources =(
id = groups;
type = ldap;
CNFieldName = cn;
UIDFieldName = cn;
IDFieldName = cn;
baseDN = “ou=Groups,dc=directory,dc=nh”;
bindDN = “”;
bindPassword = “”;
scope = ONE;
canAuthenticate = YES;
MailFieldNames = (“mail”);
displayName = “nethvm2 groups”;
hostname = ldaps://192.168.1.187:636;
isAddressBook = NO;
id = users;
type = ldap;
CNFieldName = cn;
UIDFieldName = mail;
IDFieldName = mail;
bindFields = (
mail,
uid
IMAPLoginFieldName = mail;
baseDN = “ou=People,dc=directory,dc=nh”;
bindDN = “”;
bindPassword = “”;
scope = ONE;
displayName = “nethvm2 users”;
isAddressBook = YES;
Similar situation with entering port 389:
Sogo not starting again…
Maybe it’s just my fault entering port numbers although they are optional…
Ended up with sogo not working with any setup but maybe too much binding/unbinding AD/LDAP messed up my sogo.conf in a way that there was no binddn and no password set anymore.
So I fired up a fresh VM and default anonymous bind without port is working, like you said:
Other settings, like “ldap:” with or without activated TLS are not working. Sogo is starting but you can not login. Sogo is now also working with ldaps://nethserver:636.
I don’t know what I did to mess up my sogo.conf in a way that there was no binddn and no password set anymore.
Do if the sieve filters are swipped is a big issue if we implement shared mail box
In other terms do we release this version
Latest release of nethserver-sssd should have a better probing for remote account providers, but there are no changes for local ones.
I don’t if this is a problem on SOGo or not, I can’t test it right now sorry
I will test again now I have my stuff sorted, without and with using the alias. Will have to wait till tomorrow.
not a sogo problem, it just uses what nethserver-sssd probes
I released tonight the features
set the good name@domain.com name in imap acl for openldap
migrate IMAPLoginFieldName property to CustomEmailField
set the good name@domain.com name in imap acl for sambaAD
I did not (yet) released the feature to ‘display the full name in sogo’ because it breaks the sieve filter. I would before either find a workaround or an agreement that it is not so bad.
The file /var/lib/nethserver/vmail/user@domain/sieve/sogo.sieve is not lost, it still exists, but sogo (I don’t know why) doesn’t use it anymore, and it displays like you have no rules. Even if you can see you have no rules, they are still workable…Sogo is fun.
some possible workarounds
- test in the %post section if it is an upgrade or a first install, then modify the template with a sed, or a temporary e-smith property.
- do a backup of the files sogo.sieve and let them to the admin…
- … need to catch some sleep
did the update today and i lost my contacts and also my calendar, i have no idea what happen. the mails are still there, only contacts and calendar is gone
Oups, sorry
I reverted the patch to come back to the previous state I hope. Wait some hours before to do the upgrade, or install it directly
yum install http://packages.nethserver.org/nethserver/7.4.1708/nethforge/x86_64/Packages/nethserver-sogo-1.6.16-1.ns7.sdl.noarch.rpm
okay, i guess something with the activesync did not work correct. i have with the webgui of sogo mails, calender and contacts. in my outlook, android and ios i have only mails, calendar, but no contacts
I’m pretty certain that this patch needs to be revised and/or rolled back.
There is no issue with the displaying of the name in a human friendly way, as long as you populate the proper fields in the accountprovider’s database. (in my case SAMBA AD, but I suspect OpenLDAP is the same)
The ONLY issue there was, was SOGo not setting permissions correct.
Here is a screenshot from my SOGo, without any patchwork, The only discrepancy is the fact that I set an alias everywhere, but this should not influence the display of first or last name, display name, stuff like that.
In order to test with AD account provider:
- create account on Nethserver
- open ADUC on a Windoze station and rename the user. Change the account name to the Full Name and press enter, and next fill out all the fields as good as you can.
- double click the user, set email address and any other fields which are known/common.
Go into SOGo, it will look like this:
note in picture above that the Other Users folder has the Test Account name fully displayed.
The only discrepancy is the account-name vs email, and that is only in my specific use-case. For others this would be normal.
In other words, by ‘fixing’ the way these fields are populated, you are breaking AD integration and seemingly contacts. I have tested this with and without alias, and everything is working fine out of the box, except setting rights with SOGo.
Are you using a testing repo? Or are you updating directly the main repo?
In order to avoid such things, I would use a testing repo for nethforge where people can test things before releasing them. Creating a new issue on our issue tracker and so on… What do you think?
