Hello Friends
issue with nethserver active directory file server empty data
holy god and i had connected to nextcloud i wipes nethserver and my separate nextcloud since it was connected also with the ldap even with the admin account gives me error now, so i am trying to restaure nethserver vm trying to regain access to my nextcloud
OMG
mrmarkuz
(Markus Neuberger)
November 19, 2021, 8:29pm
2
Are there errors in /var/log/messages?
Is NSDC working?
systemctl status nsdc -l
Do you have Threat Shield installed?
You may try a config restore:
@renesigi
Hi René
I’ve had that error in the past, and always was able to “fix” it by:
Removing AD Account Provider
Restoring a config backup, which restores the application AD…
Good luck!
no i haven’t threat shield installed
some of the logs
Nov 19 22:04:12 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=47929 DPT=10002 LEN=144
Nov 19 22:04:42 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=36011 DPT=10002 LEN=144
Nov 19 22:05:01 ad3 systemd: Created slice User Slice of apache.
Nov 19 22:05:01 ad3 systemd: Started Session 13 of user apache.
Nov 19 22:05:01 ad3 systemd: Removed slice User Slice of apache.
Nov 19 22:05:12 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=47524 DPT=10002 LEN=144
Nov 19 22:05:42 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=60861 DPT=10002 LEN=144
Nov 19 22:06:12 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=57576 DPT=10002 LEN=144
Nov 19 22:06:42 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=41886 DPT=10002 LEN=144
Nov 19 22:07:12 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=56927 DPT=10002 LEN=144
Nov 19 22:07:42 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=46933 DPT=10002 LEN=144
Nov 19 22:08:12 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=34112 DPT=10002 LEN=144
Nov 19 22:08:42 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=43381 DPT=10002 LEN=144
Nov 19 22:08:47 ad3 nmbd[1073]: [2021/11/19 22:08:47.358727, 0] …/…/source3/nmbd/nmbd_namequery.c:109(query_name_response)
Nov 19 22:08:47 ad3 nmbd[1073]: query_name_response: Multiple (2) responses received for a query on subnet 192.168.2.194 for name BACKUP<1d>.
Nov 19 22:08:47 ad3 nmbd[1073]: This response was from IP 192.168.2.21, reporting an IP address of 192.168.2.21.
Nov 19 22:09:12 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=58858 DPT=10002 LEN=144
Nov 19 22:09:42 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=34782 DPT=10002 LEN=144
Nov 19 22:09:43 ad3 systemd: Started Session c11 of user vitor@tpt.loc.
Nov 19 22:09:43 ad3 systemd-logind: New session c11 of user vitor@tpt.loc.
Nov 19 22:09:44 ad3 systemd-logind: Removed session c11.
Nov 19 22:09:44 ad3 systemd: Started Session c12 of user vitor@tpt.loc.
Nov 19 22:09:44 ad3 systemd-logind: New session c12 of user vitor@tpt.loc.
Nov 19 22:09:44 ad3 systemd-logind: Removed session c12.
Nov 19 22:10:01 ad3 systemd: Created slice User Slice of apache.
Nov 19 22:10:01 ad3 systemd: Started Session 14 of user apache.
Nov 19 22:10:02 ad3 systemd: Removed slice User Slice of apache.
Nov 19 22:10:12 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=37156 DPT=10002 LEN=144
Nov 19 22:10:42 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=33706 DPT=10002 LEN=144
Nov 19 22:11:12 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=38914 DPT=10002 LEN=144
Nov 19 22:11:42 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=33605 DPT=10002 LEN=144
Nov 19 22:12:12 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=48209 DPT=10002 LEN=144
Nov 19 22:12:42 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=34337 DPT=10002 LEN=144
Nov 19 22:13:12 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=50936 DPT=10002 LEN=144
Nov 19 22:13:42 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=57254 DPT=10002 LEN=144
Nov 19 22:13:49 ad3 nmbd[1073]: [2021/11/19 22:13:49.597493, 0] …/…/source3/nmbd/nmbd_namequery.c:109(query_name_response)
Nov 19 22:13:49 ad3 nmbd[1073]: query_name_response: Multiple (2) responses received for a query on subnet 192.168.2.194 for name BACKUP<1d>.
Nov 19 22:13:49 ad3 nmbd[1073]: This response was from IP 192.168.2.21, reporting an IP address of 192.168.2.21.
Nov 19 22:14:12 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=49399 DPT=10002 LEN=144
Nov 19 22:14:15 ad3 systemd: Starting Cockpit Web Service…
Nov 19 22:14:15 ad3 systemd: Started Cockpit Web Service.
Nov 19 22:14:15 ad3 cockpit-ws: Using certificate: /etc/cockpit/ws-certs.d/99-nethserver.cert
Nov 19 22:14:16 ad3 cockpit-ws: couldn’t read from connection: Peer failed to perform TLS handshake
Nov 19 22:14:22 ad3 cockpit-session: pam_ssh_add: Failed adding some keys
Nov 19 22:14:22 ad3 systemd: Created slice User Slice of root.
Nov 19 22:14:22 ad3 systemd: Started Session 15 of user root.
Nov 19 22:14:22 ad3 systemd-logind: New session 15 of user root.
Nov 19 22:14:25 ad3 cockpit-ws: logged in user session
Nov 19 22:14:25 ad3 cockpit-bridge: invalid or unusable locale: fr.UTF-8
Nov 19 22:14:25 ad3 cockpit-ws: New connection to session from 192.168.2.20
Nov 19 22:14:25 ad3 dbus[653]: [system] Activating via systemd: service name=‘org.freedesktop.hostname1’ unit=‘dbus-org.freedesktop.hostname1.service’
Nov 19 22:14:25 ad3 systemd: Starting Hostname Service…
Nov 19 22:14:25 ad3 kernel: ndpi_net_init:ns3 OK
Nov 19 22:14:25 ad3 dbus[653]: [system] Successfully activated service ‘org.freedesktop.hostname1’
Nov 19 22:14:25 ad3 systemd: Started Hostname Service.
Nov 19 22:14:26 ad3 dbus[653]: [system] Activating via systemd: service name=‘org.freedesktop.timedate1’ unit=‘dbus-org.freedesktop.timedate1.service’
Nov 19 22:14:26 ad3 systemd: Starting Time & Date Service…
Nov 19 22:14:26 ad3 dbus[653]: [system] Successfully activated service ‘org.freedesktop.timedate1’
Nov 19 22:14:26 ad3 systemd: Started Time & Date Service.
Nov 19 22:14:27 ad3 dbus[653]: [system] Activating via systemd: service name=‘org.freedesktop.realmd’ unit=‘realmd.service’
Nov 19 22:14:27 ad3 systemd: Starting Realm and Domain Configuration…
Nov 19 22:14:27 ad3 cockpit-bridge: No entry for terminal type “unknown”;
Nov 19 22:14:27 ad3 cockpit-bridge: using dumb terminal settings.
Nov 19 22:14:27 ad3 dbus[653]: [system] Successfully activated service ‘org.freedesktop.realmd’
Nov 19 22:14:27 ad3 systemd: Started Realm and Domain Configuration.
Nov 19 22:14:40 ad3 cockpit-ws: New connection to session from 192.168.2.20
Nov 19 22:14:42 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=59133 DPT=10002 LEN=144
Nov 19 22:14:44 ad3 cockpit-bridge: No entry for terminal type “unknown”;
Nov 19 22:14:44 ad3 cockpit-bridge: using dumb terminal settings.
Nov 19 22:14:46 ad3 cockpit-ws: WebSocket from 192.168.2.20 for session closed
Nov 19 22:14:59 ad3 kernel: ndpi_net_exit:ns3
Nov 19 22:15:01 ad3 systemd: Created slice User Slice of apache.
Nov 19 22:15:01 ad3 systemd: Started Session 16 of user apache.
Nov 19 22:15:02 ad3 systemd: Removed slice User Slice of apache.
Nov 19 22:15:12 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=43401 DPT=10002 LEN=144
Nov 19 22:15:31 ad3 cockpit-ws: New connection to session from 192.168.2.20
Nov 19 22:15:42 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=48086 DPT=10002 LEN=144
Nov 19 22:16:12 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=54316 DPT=10002 LEN=144
Nov 19 22:16:21 ad3 cockpit-ws: WebSocket from 192.168.2.20 for session closed
Nov 19 22:16:22 ad3 dbus[653]: [system] Activating via systemd: service name=‘org.freedesktop.hostname1’ unit=‘dbus-org.freedesktop.hostname1.service’
Nov 19 22:16:22 ad3 systemd: Starting Hostname Service…
Nov 19 22:16:22 ad3 kernel: ndpi_net_init:ns4 OK
Nov 19 22:16:22 ad3 dbus[653]: [system] Successfully activated service ‘org.freedesktop.hostname1’
Nov 19 22:16:22 ad3 systemd: Started Hostname Service.
Nov 19 22:16:22 ad3 cockpit-bridge: No entry for terminal type “unknown”;
Nov 19 22:16:22 ad3 cockpit-bridge: using dumb terminal settings.
Nov 19 22:16:27 ad3 cockpit-ws: New connection to session from 192.168.2.20
Nov 19 22:16:38 ad3 cockpit-ws: WebSocket from 192.168.2.20 for session closed
Nov 19 22:16:39 ad3 cockpit-ws: New connection to session from 192.168.2.20
Nov 19 22:16:42 ad3 kernel: [UFW BLOCK] IN=br0 OUT= MAC=33:33:00:00:00:01:68:d7:9a:5a:bf:30:86:dd SRC=fe80:0000:0000:0000:6ad7:9aff:fe5a:bf30 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=184 TC=0 HOPLIMIT=1 FLOWLBL=0 PROTO=UDP SPT=33312 DPT=10002 LEN=144
By the way i was able to restore the vm nethserver aand connect again to my nextcloud is only the samba files are empty i have something blocking it …or sssd problem but i can logi and authenticate on samba shares and ldap nextcloud based
mrmarkuz
(Markus Neuberger)
November 19, 2021, 10:10pm
6
Maybe a file permission problem?
Did you try to restart the smb service?
systemctl restart smb
I will gonna try tomorrow Markus and send you the results
dnutan
(Marc)
November 20, 2021, 2:39pm
9
Did the problem started after some update?
Do you use a desktop environment on the server?
Does the server has an additional firewall (UFW - Uncomplicated FireWall)? If so, try stopping and disabling it.
vm into proxmox the nethserver has no gui and is shorewall normally by default …promox has ufw …
mrmarkuz
(Markus Neuberger)
November 20, 2021, 10:39pm
11
You can disable the proxmox firewall in the network device setting of the vm:
Hi Andy, in fact from what you wrote to me I had no doubt that everything worked with the version of cluster 6.0, unlike the 7 that seems to want to work only if the configurations of the vlan remain on the same node and are not rotated on the other nodes. From your configuration that is very similar to mine, I attach screenshots that show how it works only at the single node level.
[at]
[Schermata 2021-11-11 alle 06.33.10]
[fw]
As you can see, on the pfsense the vlan 200 cond dhcp is activ…
france
(Francesco)
November 21, 2021, 8:22am
12
Hi Markus, yes the firewall has already been disabled, believe me at the moment I tried them all and as @Andy_Wismer says it must work without changing the vlans on the switch. Thank you
