hum I recall something like this mybe in my test
Nice progress
Thank a lot for you help, Letâs break it to improve it. I have some others things on the stove, but I am still available
Iâll give it a try on the weekend, and keep you posted.
Iâve managed to deploy piler based on the steps described in the wiki, and it went smoothly. Great work, Stephane!
Iâll write a blog entry that Nethserver supports piler.
yeahhhhh
This is the blog entry: https://mailpiler.com/running-piler-on-nethserver/
Let me know if thereâs something to add, clarify or fix.
Beer for two? If is suits your tasteâŠ
Not quite, but I appreciate your intention
hello,
can i install piler in a second NS server ? the first one is doing mail jobs but has a small diskâŠ
Designed to be on a host with the email stack, we could think to do differently but the container cannot use the smtp ports, we have to create container which listen on custom ports and do a BCC to the remote host
In term of security I see benefits, however this needs some works, it is not possible to get another drive and use a mount to the /var/lib/docker
I installed piler today. It seems to be a no-brainer. Many thanks to @stephdl with support from @jsuto creating this package.
One question to @jsuto: Is there an overview somewhere to compare the Enterprise and Community versions?
best regards, Marko
A new experience with multiple mail domains:
So far piler only forwards mails addressed to the main domain to the archive.
Wouldnât it be a better solution to define the forwarding in the settings generally and for all domains?
Otherwise, the forwarding would have to be configured manually at each mail domain. You have to come up with this first, there is nothing about it in the documentation.
On holiday right now and only a smartphone in my hand, lets talk next week and surely ping me if I forget
IIUC you want to use one BCC to avoid to set the BCC in each email domains. Do I am right ?
Reading the documentation
The address will be the same for each domain archive@piler.domain.org where domain.org is your first created domain.
So your request should be workable
I have two mail domains configured.
mydomain1.de is the main Domain with mail.mydomain1.de and the same RDNS.
mydomain2.de an additional mail domain.
Thats why I configured:
db domains setprop mydomain1.de AlwaysBccAddress archive@piler.mydomain1.de AlwaysBccStatus enabled
signal-event domain-modify mydomain1.de
After that I noticed that not all mails were archived.
So I repeated the procedure for the 2nd domain.
db domains setprop mydomain2.de AlwaysBccAddress archive@piler.mydomain1.de AlwaysBccStatus enabled
signal-event domain-modify mydomain2.de
Now are all mails are archived.
My suggestion was to use the email settings to forward all mail to the piler archive and save the need for multiple configuration.
âŠwas not enaugh.
maybe you are right, I thought that to use the same archive@piler.firstdomain.org was enough, but we probably need to set it individually ???
https://www.mailpiler.org/wiki/current:post-install?s[]=*config&s[]=site&s[]=php*
How does it works, does the email of the two domains are sent to the archive ?
yes ist works
