mrmarkuz
                (Markus Neuberger)
                    April 20, 2023,  3:09pm
              1
              Hi friends,
please test the new Onlyoffice module with the latest DocumentServer 7.3.3.
@transocean  @rasi  @Denis_Pollini  @roberto.schiano
yum -y install https://mrmarkuz.dynu.net/mirror/mrmarkuz/7/noarch/nethserver-mrmarkuz-0.0.1-6.ns7.noarch.rpm
yum -y install https://downloads.sourceforge.net/project/mscorefonts2/rpms/msttcore-fonts-installer-2.6-1.noarch.rpm
yum -y install https://github.com/ONLYOFFICE/DocumentServer/releases/download/v7.3.3/onlyoffice-documentserver.x86_64.rpm
yum -y install https://mrmarkuz.dynu.net/mirror/devtest/nethserver-onlyoffice-0.0.3-1.ns7.noarch.rpm
Changes:
Switch from supervisord to systemd
Add new secret string for better security
Add DB upgrades
Changed metrics statsd port from 8125 to 8126 to not conflict with netdata
Because of these changes you shouldn’t use older DocumentServer versions < 7.3 with the new nethserver-onlyoffice 0.0.3-1 module. Thanks in advance for testing!
              Hi@mrmarkuz,
Error after error after I pressed save in the settings of Onlyoffice in Nextcloud. See picture below.
              Forget what I wrote. According to @Andy_Wismer ’s motto “Reboot always does good”, it works now.
Regards and thanks for the good job.
Uwe
                mrmarkuz
                (Markus Neuberger)
                    April 20, 2023,  5:15pm
              4
              Thanks for testing!
You found a bug, the services were not restarted after the update. I uploaded a fixed module.
If you already installed the buggy version execute
yum -y reinstall https://mrmarkuz.dynu.net/mirror/devtest/nethserver-onlyoffice-0.0.3-1.ns7.noarch.rpm
to get the fixed version.
                pike
                (Michael Kicks)
                    April 20, 2023, 11:04pm
              5
              Someone give this man a beer. Or a coffee. Whatever he prefer.
I’m not currently interested into this particular module but… more tests, more opportunities for finding bugs… faster good release.
