Hello,
how can I change the environment variable in Nethserver from “LANG=en_US.UTF-8” to “LANG=de_DE.UTF8”? I’m not familiar with Centos.
Thanks for your help.
Hello,
Hello,
Go in the software center.
And install the german language
Edit: If it for a physical keyboard plug on the server, for the CLI
https://www.centos.org/forums/viewtopic.php?f=47&t=49942
If you need to change the language of the web interface, follow Jim advice.
If you want to change the system language, you need to manually edit @/etc/sysconfig/i18n@.
Thanks. I want to change the system language. Are there any constraints if I change sysconfig?
No, the system language is used almost only for command line.
IMHO, a command line in English is much better
It depends. Postgresql creates its cluster in the system language. A database cluster in american English is not very helpful.
