Nethserver installation on Centos 7.8.2003 Fails
NethServer Version: ethServer release (7.7.1908)
I am trying to Install Nethserver, but i am geeting the error.
[WARNING] CentOS release (7.8.2003) should match NethServer release (7.7.1908)!
AFAIK, no NethServer for CentOS 7.8 currently released.
oops, and thats the only version of centos 7 available for me to install, when is it expected to be available. Looks like most vps providers have already updated
@dev_team
You may downgrade Centos to 7.7:
https://www.tecmint.com/downgrade-rhel-centos-to-previous-minor-release/
but when nethserver 7.8 is released, i will be able to upgrade back. right.
And when is Nethserver 7.8 coming out. i saw on the repo page it is there, but not on main release
Yes.
I don’t know but no hurry! Better test and ensure stability than releasing too quick.
We are almost there, at least for a ā€œdevelopmentā€ mode that might be a workaround for you, once it has been merged.
@davidep i think i will go with that option.
I have been trying to downgrade, and am not sure where the issue is.it is not possible on this server to downgrade. though i have tried on other servers.
Let me install the dev version of nethserver 7.8,
Question, when the final release is available, what will have to change?
@davidep i can even see the github page is being updated actively. as we are discussing here.
So should i sit on for the 7.8 release, looks like it is some few hours away
The PR was approved and merged.
Check out development instructions here:
Remove the template-custom
