Nethserver impossible installation
NethServer Version: 7
Module: your_module
After downloading nethserver 7 into a usb stick and bootin from it, I could not finish the installation of nethserver. The screen shows at the end the error PANE IS DEAD.
Then I supposed that something went wrong in the usb, so I tried to burn the image in another different usb from a different computer, but the error was the same.
What a pity, this project liked me very much but I’m a little disappointed with the installation.
Any ideas?
Thank you.
Hi Joan, welcome here.
Take a look at this helpful post by @dnutan it might help you
If you get the error again, check other text messages on the screen or try to access the log to get some hints about what could be the cause.
SOLVED:
I choosed the COPY DD METHOD instead of creating standard usb image method. I used RUFUS program in windows. Then, it worked like a charm.
Thank you and sorry for my ignorance.
I hope that documentation will be soon updated with tests done by @dnutan. Which was really precise and complete in testing (and reporting)
