Installed testenviroment with 2 vms.
Save Button works. => database props are changed.
Hotsync button seems to work. => root directory on slave is identical with master!
Dashboard looks great.
The promote button doesn’t seem to work correctly.
But I think it shouldn’t be there at all. The restore of the slave to the master should be done on CLI IMO.
It’s essential to read the output of the promote command and only if it’s output is o.k. to give the post restore data event. So I don’t know how to this without command line.
I vote for let the restore procedure completely at the command line and cancel the promote button.
Maybe a Info box with a link to the documentation and a hint to do restore on CLI would be better.
What do you think? /cc @mrmarkuz
Nevertheless thanks for this wonderfull work @federico.ballarini
You deserve at least for it!
Logs should be or not should be synced?
IMVHO there are PROS (historical records of activities, GDPR, so on) and CONS (logs could be unrelated to the installation, therefore could not be useful for troubleshooting the new/slave installation)
I do not have any preference for the hotsync.
As a general rule, if you can do something in the UI without too many problems, go with it.
If the process is really hard to automate, go with the command line
