Hi guys! I just released (for NethServer 7.9.2009) the new HotSync version that contains two bug fix related to cron and permissions fix.
- HotSync: cron sync and avoid execution on slave host - Bug NethServer/dev#6328
- HotSync: permissions are not fixed after master sync - Bug NethServer/dev#6335
An important note for this release is to perform an update event on slave machine. You can read about it here: HotSync — NethServer 7 Final
If you have configured slave host before release 2.2.0, update to a newer one on master and slave with yum update -y nethserver-hotsync –enablerepo=nethforge or from Software Center. After that, on slave host, launch signal-event nethserver-hotsync-save or do it from Cockpit HotSync interface by pressing Save button.
Happy hacking! ![]()
