Yes!! ![]()
@dz00te preparing nethserver release and mock, which repo settings?
http://mirror.framassa.org/nethpi/
-OR- ??
Done, should we set the release to something else?
ie 7.2.1511.a (a for arm)
As you wish, but nethserver-arm is ok For me
I was afraid it would not update, just update an old install;
to be frank it does not break but there are some errorsâŚ
nethpi is OK, going to pack it now and ill pm you a link
I think we can leave the same release. @dev_team what do you think?
tnx to @mark_nl updated the repo, updated also the wiki http://wiki.nethserver.org/doku.php?id=ns_raspi2
Centos arm-devâs started building Epel for aarch64
https://lists.centos.org/pipermail/arm-dev/2016-May/002034.html
Gues itâs time to acquire some new hardware.
Continuing the discussion from Nethserver on Raspberry Pi:
Can someone fill me in on this?
If you are in hurry you can rebuild it for arm
Removing the dependency requires to delete some lines from the esmith::util library; we can do it for alpha3!
Thanks, for armv7 this source doesnât build due to differences in naming the arch (âarmv7â vs âarmâ vs âarmhfpâ).
I am having a go on aarch64 and this build oke.
For armv7 It can be build from a older source; a test fails due to different locale settings (systemd);
I donât like to end up with different sources for 32- (armv7) and 64 bit (aarch64).
BTW nethserver-base runs fine on aarch64 ![]()
Thanks @mark_nl, donât waste your time on this package: @giacomo is going to clean up the dependency so we can get rid of it!
Dependency removed.
Here you are the test package: http://packages.nethserver.org/nethserver/7.2.1511/testing/x86_64/Packages/nethserver-lib-2.1.5-1.16.g609fc8b.ns7.noarch.rpm
Edit: you need also this http://packages.nethserver.org/nethserver/7.2.1511/testing/x86_64/Packages/nethserver-base-2.10.2-1.101.g4bbfaac.ns7.noarch.rpm
Thanx,
Although nethserver-directory still depends on perl-Crypt-Cracklib
(there is no rush: weâve got a package. If the dep stayâs it need cleaning up)
RightâŚI will investigate on it.
I removed also this dependency, I hope itâs the last one
Here you are the rpm on testing: http://packages.nethserver.org/nethserver/7.2.1511/testing/x86_64/Packages/nethserver-directory-2.3.0-1.72.g7549af9.ns7.noarch.rpm
Installs and works on armv7, Nice! ![]()
Did just a simple functional test though: fill in a weak password and a appropriate error message shows up.
