Nethserver.de-labrusse.fr
I synchronize your mirror each hour, available at http://nethserver.de-labrusse.fr/
I use rsync
rsync --progress -aHS --partial --delete-after rsync://pulp.nethserver.org/nethserver/ /your/directory/
what is lacked/needed
  • a timestamp file in the root folder, to see if the mirror is synchronized or not
  • in the /etc/yum.repos.d/NethForge.repo it is needed to use a ‘mirrorlist’ instead of baseurl’
  • a web page to see status mirror
I like this man! :+1:
Right @stephdl! Just updated NethForge page here for 6.6 and mirrorlist support:
http://dev.nethserver.org/projects/nethforge/wiki/NethForge
Timestamp file will be added soon. About synchronization frequency: I was reading CentOS mirror howto: they speak about 2-4 times per day, so I was thinking about 0,6,12,18 UTC for my mirrors.
For rsync command: use “mirror.nethserver.org” in place of the legacy “pulp”.
Since your rsync server has two modules (nethforge and nethserver), do I need to download and use each one in a virtualhost, or use both in the same virtualhost. In case of the last proposition, what about of the ‘centos’ folder which is not downloaded -> http://mirror.nethserver.org/
The easier solution could be to get just one module, and use it to sync the whole repository.
actually if I use your url I get this
$ rsync --progress -aHS --partial --delete-after rsync://mirror.nethserver.org /var/www/vhosts/de-labrusse.fr/nethserver/
nethserver
nethforge
and thus I need to download separately each module.
Ok, I’ll arrange in the same way of 6.5
Done. Changed my mirror configuration. In /etc/cron.d/sync-nethserver-mirrors:
RANDOM_DELAY=10
CRON_TZ=UTC
0 0,6,12,18 * * *	root	/usr/local/sbin/sync-nethserver-mirrors
In /usr/local/sbin/sync-nethserver-mirrors:
#!/bin/bash
/usr/bin/rsync -aq --delete-after \
    rsync://mirror.nethserver.org/nethserver \
    /var/www/repos/nethserver/
Updated nethserver-nethforge-release RPM. Now you can install from nethserver-base!
When the mirror is ready, can be add it to the official list? @stephdl
I also would like to setup mirrormon: http://www.staff.science.uu.nl/~penni101/mirmon/
Of course you can add me to the official repository, the server is located in Germany at 1&1. I have planned to migrate to online or ovh, but I will inform you. I do Love free Software (did I never say it :slight_smile: ) and it is just one way on my personal involment.
Concerning mirmon, it is a good choice.
The mirror is in sync, maybe a good english writer should start a documentation on how to do a mirror for other people.
This is a great present for our community! Thanks @stephdl
PS
Still lacking the timestamp file, will fix tomorrow!
Kudos for @stephdl :+1:
Just added.
Added also timestamp.txt on the module root.
Until somebody sets up mirmon or similar, this is my mirror monitor bash function in .bashrc:
nethserver_mirrors ()
for M in $(curl ‘http://mirrorlist.nethserver.org/6.6/nethserver?repo=base&arch=x86_64&release=6’ 2>/dev/null | sed ‘s|6.6/base/x86_64/||’);
do
printf ‘%-47s %s\n’ $M “$(curl -q -L “${M}/timestamp.txt” 2>/dev/null)”;
done
vale, https://nethserver.de-labrusse.fr/plesk-stat/webstat/
I moved 2 posts to a new topic: How to set up a mirror.nethserver.org mirror
I moved a post to an existing topic: How to create your own NethServer mirror
