Nethserver-dc hardware requirements?
So I worked out that nethserver-dc runs its AD in a container.
Can any one tell me does this mean your hardware has to be capable of virtualisation?
I ask as I’m having issues setting up AD on my Atom D2550 based computer.
Thanks in advance for any useful info
I think it does not need any special requirement. AFAIK it does not need any CPU extension for virtualization. Please refer to
http://docs.nethserver.org/en/v7rc/installation.html#minimum-requirements
I am absolutely not an expert on LXC, but what I understood, you need some kernel options. You need at least Linux kernel 2.6.32 to use LXC. If you need to use LXC-attach, you need at least kernel version 3.8 ( see https://linuxcontainers.org/lxc/getting-started/)
Can you elaborate on the issues you encounter?
