Workstations
Windows 10 Pro
22H2
19045.2846
Windows Feature Experience Pack 120.2212.4190.0
Nethserver is up-to-date. Nethserver is PDC with AD. Applying the latest nethserver-dc (nethserver-dc-1.9.2-1.ns7.x86_64) is breaking samba shares and net connections from workstations to the server. Downgrading to nethserver-dc-1.9.1-1.ns7.x86_64 fixed this issue.
We also still have winxp clients - I confirm, that with the new version of nethserver-dc the clients are not able to connect to any share of the domain. Rolling back solved the issue for the xp clients too.
In our company WinXP OS is (and will be) still in use for some of our drilling machines. It’ll never happen, that we’ll replace a machine because EOL of the PC OS. That would never ever make any sense.
BTW we do also have machines with (different) MacOS. As I already said - the costs of replacing machines because of software updates or EOL of an OS, will never be a discussion.
What details are needed? If I am guided I can provide information.
I can understand it, but the Samba team can’t support discontinued OS.
Nothing for these kind of machines. The only thing you can do is trying the workaround posted in my previous message. Or, as you already did, keep the old nethserver-dc version but keep in mind that it wont work with newer clients.
If you have a NS7 as samba client, we’d appreciate to have the version of involved packages (at least samba and nethserver-samba). Also the log of both client and server are very important to track down the issue.
If you have troubles with Nextcloud, post also relevant part of Nextcloud log.
In the meanwhile, we have conducted the following tests (thanks to @nrauso!):
NS7, updated, on which we have installed nethserver-dc-1.9.2-1.ns7.x86_64, ibay, and nethserver-nextcloud-1.22.0-1.ns7.noarch:
We accessed the ibay using smbclient:
We accessed the ibay from a Windows 11 client not joined to the domain:
We accessed the ibay from a Windows 11 client joined to the domain:
We configured the ibay as an external storage on Nextcloud:
Another NS7, updated, joined to the NS7 acting as a DC, with nethserver-nextcloud-1.22.0-1.ns7.noarch:
We accessed the remote ibay using smbclient:
We configured the remote ibay as an external storage on Nextcloud:
In all cases, if there are ACLs configured on the ibay, we confirmed that they are respected.
Is this OS also already discontinued? As I posted, nethserver-dc-1.9.2-1.ns7.x86_64 did not work.
We don’t use nextcloud - the different clients needs to have access to files on shares (ibays), that’s all.
IMVHO that’s exactly what
SME (Small and Medium-sized Enterprises) server should cover. Regardless if an OS is still supported from M$ or not. And regardless if the shares are providing files for machines, or i.e. if the business is a lawyer or consultant office. In any other case I feel like walking to the dead end M$. Means everybody should immediately update to WIN11. Seriously?
This is nothing personal against anybody in here - it’s just my very personal opinion.
For those who installed the above mentioned updates - try to uninstall. Yes, this can be a pain. Then tell windows not to update. There are a few ways to do this. Additionally/optionally downgrade to nethserver-dc-1.9.1-1.ns7.x86_64. Lock this version with yum versionlock at least, as the smoke is gone. If you are dealing with DNS-blacklists you may want to block wsus servers in your router/firewall/pi-hole. This one may be of help: GitHub - schrebra/Windows.10.DNS.Block.List: Windows DNS Block List. READ THE BLOCKLIST CAREFULLY. Adjust where needed.
This is a workaround - not a fix. But at least your clients are able to access the server resources.
