@stephdl about NFR
I most like “Nurses for Reform”
I got it: New Feature Request. Oh Friday, 13th. I need a weekend. I’m going for beer.
cheers.
And I have faith in your skills, stephane. I’m sure you will get a solution.
@stephdl about NFR
cheers.
Chaque problème a au moins une solution. Si il n’y a pas de solutions, c’est qu’il n’y a pas de problème.
Every problem has at least one solution. If there are no solutions, is that there is no problem.
Nethserver 7.2 RC2
Crontabmanager 0.7
After i restore a Configuration Backup, i am not able to use Crontabmanager again. I uninstall it, install it reinstall it etc. It shows the old entrys but dont work. If i try to edit or delete the entrys i got an error “The remote server is not reachable” Samba is still present. Any Ideas?
Do it again and try to catch the full event nethserver-crontabmanager-update complete.
tailf /var/log/messages
Nethserver-crontab-manager doesn’t use samba I guess you found a bug with the Configuration Backup and its restoration
you mean that the cron jobs are not launched ???
what is the status of crond
systemctl status crond
â crond.service - Command Scheduler
Loaded: loaded (/usr/lib/systemd/system/crond.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2016-11-20 10:27:51 CET; 2h 19min ago
Main PID: 2180 (crond)
CGroup: /system.slice/crond.service
ââ2180 /usr/sbin/crond -n
Nov 20 10:27:51 systemd[1]: Started Command Scheduler.
Nov 20 10:27:51 systemd[1]: Starting Command Scheduler…
Nov 20 10:27:51 crond[2180]: (CRON) INFO (RANDOM_DELAY wil…)
Nov 20 10:27:51 crond[2180]: (CRON) INFO (running with ino…)
Nov 20 10:43:01 crond[2180]: (system) RELOAD (/etc/crontab)
Nov 20 10:46:01 crond[2180]: (root) CAN’T OPEN (/etc/cront…y
Nov 20 10:56:01 crond[2180]: (root) CAN’T OPEN (/etc/cront…y
Hint: Some lines were ellipsized, use -l to show in full.
[root@sbs ~]#
Wow, cool! Why did i not see this earlier?
take a look to modules [NethServer Wiki]
You don’t answer to my qestion please, moreover try to paste the answer that I can read it in a comfortable way
If you don’t do that the lines are break and it is quite impossible to read it ![]()
sorry stephane, i dont get it right yesterday, i try today
Let us know about your tests!
Un message a été déplacé vers un nouveau sujet : Cron doesn’t work
