Hello, has anyone had any luck setting up a vpn from nethserver to a mikrotik router?
Hi Kris,
Did you try the mikrotik wiki? There is a very extensive documentation about openvpn there.
See http://wiki.mikrotik.com/wiki/OpenVPN
Howto: http://wiki.mikrotik.com/wiki/OpenVPN_Configuration_Step_by_Step
@robb Yes, i use mikrotik routers everyday in your wisp. the step by step is how to use a mikrotik router as a openVPN server. I think something as easy as a vpn #1 on the list. Openvpn is great when you can get it to work, but it is not something that you use when u are doing router to router (i never have) more from server to end user.
- openvpn only dose the openvpn in nethserver right? it has nothing to do with ipsec right? I hate to install a vpn server on top of this just to vpn.
