Hi all,
I am looking at installing Discourse forum on my LOCAL development virtual machine.
All is working correctly…
… except:
- Discourse display the above registration page and I have to “register a new account to get started”.
I click Register. - The " Register Admin Account" page is displayed.
My email address titi@toto.com I entered when I installed Discourse is automatically displayed.
I enter a user name and password. I click Register. - The " Confirm your Email" page is displayed saying “We sent an activation mail to titi@toto.com . Please follow the instructions in the email to activate your account.”
I receive no email.
At the console of the LOCAL Discourse server, I can send manually an email to titi@toto.com without problem and he receives it.
The configuration for the email In the app.yml file of Discourse:
## TODO: The SMTP mail server used to validate new accounts and send notifications
# SMTP ADDRESS, username, and password are required
# WARNING the char '#' in SMTP password can cause problems!
DISCOURSE_SMTP_ADDRESS: mail.toto.com
DISCOURSE_SMTP_PORT: 587
DISCOURSE_SMTP_USER_NAME: michelandre@toto.com
DISCOURSE_SMTP_PASSWORD: "michelandre-password"
The NethServer running toto.com is directly connected to the Internet
The user michelandre is in the admin group at toto.com.
All the CNAME at the domain registrar are all entered and working correctly.
If I run: /var/discourse/discourse-doctor
==================== MAIL TEST ====================
For a robust test, get an address from http://www.mail-tester.com/
Sending mail to REDACTED . .
Testing sending to titi@toto.com using michelandre@toto.com:michelandre-password@mail.toto.com:587.
======================================== ERROR ========================================
Connection to port 587 failed.
====================================== SOLUTION =======================================
The most likely problem is that your server has outgoing SMTP traffic blocked.
If you are using a service like Mailgun or Sendgrid, try using port 2525.
QUESTIONS:
- Is the mail.toto.com right or do I have to specify imap.toto.com, or smtp.toto.com, or something else?
- Is the port 587 the right one to use?
- Is michelandre@toto.com the right user to connect to the mail server of toto.com?
Any suggestion appreciated,
Michel-André
