NEthserver 8 Modules Generator
Yeah Am currently working on that
Also Checking on how to set items that can be set on module creation and the one that can be set on configure
I found that also the backup/restore process was implemented for mariadb but postgresql is used for example in planka.
The current issues have been fixed
To get started using
rm -rf template
So as to download the latest template v0.0.2
Am looking for was on how i can implement backup and restore easily and also checking on was on how to add databases to create-module
The module generator now supports backup and restore for common databases such as
  • Postgres
  • Mariadb
  • Mysql
To get started
First remove the old template to download the latest template
rm -rf template
Happy testing
Also remember to change the database names currently the database names are not being set correctly
Will make the generator much smarter on the next update
Added Generating of modules using remote yaml
