Nethserver 7 + Wireguard
I’m new with Nethserver.
I tried using Nethserver 8, but I decided to stick with version 7.9…
I need to create an AD, but the connection must be made via Wireguard.
I found some topics to install with Nethserver, but I was not successful in accessing via the web, etc…
Does anyone have a step-by-step procedure that works?
Hi and welcome to NethServer Community.
NethServer 7.9 is based on CentOS 7 and it’s EOL in the end of June, see also What to know about CentOS Linux EOL
hello @thyte. welcome to nethserver community.
I am curious, is your server hosted on premise or in the cloud?
Yes, but version 7 seemed better and had more options. Version 8 didn’t work very well for me.
Cloud, however access will be done via VPN (Wireguard)
If you can guide me on the best way to enable Wireguard, I would appreciate it.
When I start wg-manager I receive these errors.
@thyte if my memory serves right, for you to use AD in NS7, you need to have configured a dummy interface.
Wg manager is only an interface and requires wire guard already installed and configured.
Sorry, the wg-manager doesn’t work, see module:wireguard [NethServer Wiki]
