NethServer Version: 6.9
Module: mail sogo owncloud backup
Hallo again !
at the moment we use Neth6.9 as a simple workstation in DMZ = orange LAN of iPFire-Firewall.
Now we tried to upgrade to Neth7.x. But there are much confusion, because of Neth7 out of the box don’t support simple workstation mode, I think these is the reason of confusion!
IS THERE A WAY TO CONFIGURE NETHSERVER 7 as SIMPLE WORKSTATION like NETH6 ??
Hi @rowihei,
You can use NS7.x “as SIMPLE WORKSTATION like NETH6”, for your purpose, choosing LDAP as local accounts provider as domain account.
Gabriel
If you need authenticated access to shared folders configure a local ad accounts provider. See
http://docs.nethserver.org/en/v7/accounts.html#choosing-the-right-account-provider
http://docs.nethserver.org/en/v7/upgrade.html#primary-domain-controller-and-workstation-upgrade
If you already have some kind of accountprovider running in your network (either LDAP or Samba4/AD) you can join your NS7 server to that domain. It will be acting as a normal “member” of your domain and use any account credentials already available on your network.
Thank you for your tip - but I already tried this - sadly not the same structure in sogo-email;
neth6.x >> Email addresses
Email … … … … … … Account Attributes Actions
max.muster@firma.de … user8 - Edit^
After upgrade to Neth7 as LDAP (Local) NOT the same structure and a little bit chaos
Thank you for your post,
but your idea is a little bit complicated, because nethserver in orange LAN (DMZ) and AD-Server is Windows2012 in green LAN. Firewall is a IPFire with red-green-blue-orange.
We don’t like pinholes from orange to green …
