So, about this…
The package that will let you update to NethServer 7.8 has been released.
It will be available from the Software Center as soon as all mirrors are in synch.
If you have rush, use the command from this post.
I was just writing it when I saw your message popping out! ![]()
[root@neth ~]# yum update --enablerepo=nethserver-testing nethserver-subscription
Loaded plugins: changelog, fastestmirror, nethserver_events, priorities
* sb-base: u3.nethserver.com
* sb-centos-sclo-rh: u3.nethserver.com
* sb-centos-sclo-sclo: u3.nethserver.com
* sb-epel: u3.nethserver.com
* sb-extras: u3.nethserver.com
* sb-nethserver-base: u3.nethserver.com
* sb-nethserver-updates: u3.nethserver.com
* sb-updates: u3.nethserver.com
nethserver-testing/7/x86_64/signature | 836 B 00:00:00
nethserver-testing/7/x86_64/signature | 2.9 kB 00:00:00 !!!
nethserver-testing/7/x86_64/primary_db | 191 kB 00:00:00
Resolving Dependencies
--> Running transaction check
---> Package nethserver-subscription.noarch 0:3.5.4-1.ns7 will be updated
--> Processing Dependency: nethserver-subscription = 3.5.4-1.ns7 for package: nethserver-subscription-ui-3.5.4-1.ns7.noarch
---> Package nethserver-subscription.noarch 0:3.6.1-1.ns7 will be obsoleting
---> Package sclo-php71-php-pecl-imagick.x86_64 0:3.4.4-1.el7 will be obsoleted
---> Package nethserver-subscription-ui.noarch 0:3.5.4-1.ns7 will be updated
---> Package nethserver-subscription-ui.noarch 0:3.6.1-1.ns7 will be an update
Dependencies Resolved
Package Arch Version Repository Size
Installing:
nethserver-subscription noarch 3.6.1-1.ns7 nethserver-testing 51 k
replacing sclo-php71-php-pecl-imagick.x86_64 3.4.4-1.el7
Updating for dependencies:
nethserver-subscription-ui noarch 3.6.1-1.ns7 nethserver-testing 26 k
Transaction Summary
Install 1 Package
Upgrade ( 1 Dependent package)
Total download size: 77 k
Is this ok [y/d/N]: y
Downloading packages:
No Presto metadata available for nethserver-testing
(1/2): nethserver-subscription-ui-3.6.1-1.ns7.noarch.rpm | 26 kB 00:00:00
(2/2): nethserver-subscription-3.6.1-1.ns7.noarch.rpm | 51 kB 00:00:00
Total 140 kB/s | 77 kB 00:00:00
Running transaction test
Transaction test succeeded
Running transaction
Installing : nethserver-subscription-3.6.1-1.ns7.noarch 1/5
Updating : nethserver-subscription-ui-3.6.1-1.ns7.noarch 2/5
Cleanup : nethserver-subscription-ui-3.5.4-1.ns7.noarch 3/5
Cleanup : nethserver-subscription-3.5.4-1.ns7.noarch 4/5
Erasing : sclo-php71-php-pecl-imagick-3.4.4-1.el7.x86_64 5/5
Verifying : nethserver-subscription-ui-3.6.1-1.ns7.noarch 1/5
Verifying : nethserver-subscription-3.6.1-1.ns7.noarch 2/5
Verifying : nethserver-subscription-ui-3.5.4-1.ns7.noarch 3/5
Verifying : sclo-php71-php-pecl-imagick-3.4.4-1.el7.x86_64 4/5
Verifying : nethserver-subscription-3.5.4-1.ns7.noarch 5/5
Installed:
Dependency Updated:
Replaced:
Complete!
[root@neth ~]# signal-event software-repos-upgrade
[root@neth ~]# yum upgrade
No packages marked for update
I don’t think it’s a matter of “rushing” or being impatient to wonder what’s going on with an update that (it was said) was going to be released a week ago. Especially when the ImageMagick thing is preventing updating anything else.
This topic was automatically closed after 6 hours. New replies are no longer allowed.
