one day we should compare our junk mail, curious to see yours
Thanks…
And of course, hint worked flawlessly.
The BETA iso is out: http://mirror1.nethserver.org/beta/
Download and report here
- md5 0e69e9096289451d757f1e73208bef91
- sha1 8a864e81d375bee4b6c1ba4b7375aea643647c33
.torrent ~1GB
E34DD54530C4842F5073D62DDC8B12C2E8C3314B
To enable the 7.6 repos after the install, execute:
config getprop sysconfig Version > /etc/yum/vars/nsrelease
/cc @quality_team
/cc @LayLow I added the command to enable the repos
Oops here with an unattended install in virtualbox with 1 para virtualized adapter bridged and another adapter as Intel 1000.
Edit. Prob not an Oops, needed to hit ‘enter’ to get the root login prompt…
Edit 2: Yum update shows:
Edit 3:
Quick and (very) dirty commands to upgrade to beta2:
yum install http://packages.nethserver.org/nethserver/7.6.1810/testing/x86_64/Packages/nethserver-release-7-10.1.g20ee02e.ns7.noarch.rpm http://packages.nethserver.org/nethserver/7.6.1810/updates/x86_64/Packages/nethserver-subscription-3.2.1-1.ns7.noarch.rpm -y
mv -f /etc/yum.repos.d/NethServer.repo.rpmnew /etc/yum.repos.d/NethServer.repo
signal-event software-repos-save
yum update -y
updated from beta to beta 2 via softwarecenter without issue (so far
