Mille grazie!
-HF
The firewall packages have been released!
I’m working on the last feature Repository metadata GPG signature
Dependency failed for Network Manager Wait Online
Could you determin the reson of the message?
Let me see if it’s reproducible. Anyway it doesn’t seem an issue…
I agree. It doesn’t seem to be an issue, or at least that it has no effect.
I just was curious.
Thx for reply.
Unlocked settings, a lot of packages downloaded. But still 7.5.1804.
yes, unlocked downloads centos 7.6, but retain ns 7.5: it can’t work by now…
To complete the upgrade to 7.6 (almost beta):
config setprop subscription NsRelease 7.6.1810
Then go to Software Center and run system upgrade.
Hi all!
Today I have installed an email server from scratch, starting with NethServer 7.5.1804 final and ending with NethServer 7.6.1810 (beta).
As usual, is a bare-metal server, placed in DMZ.
Everything without any issue, following this steps:
Now, I begin to create the users.
From tomorrow, the email server will be in tests.
Upstream dropped the support for PHP 5.6, but we are still publishing PHP 5.6 RPMS from CentOS 7.5 to provide backward compatibility.
More information will follow inside the release notes.
It happens from time to time. You can safely ignore it.
To fix, clean the yum cache.
It’s not an issue, however until 7.6 final is out (and we switch the stable repository from 7.5 to 7.6) you need to enable the “Locked” policy on 7.6.1810 to get rid of it (hopefully).
I did yum clean all and yum update.
I will wait till next cron job to see.
Thank you!
[root@mail ~]# yum clean all
Cleaning repos: ce-base ce-extras ce-updates centos-sclo-rh centos-sclo-sclo
: epel nethforge nethserver-base nethserver-updates
Cleaning up list of fastest mirrors
[root@mail ~]# yum update
Determining fastest mirrors
epel/x86_64/metalink | 25 kB 00:00
* ce-base: mirror.yandex.ru
* ce-extras: mirror.yandex.ru
* ce-updates: mirror.yandex.ru
* epel: mirror.yandex.ru
ce-base | 3.6 kB 00:00
ce-extras | 3.4 kB 00:00
ce-updates | 3.4 kB 00:00
centos-sclo-rh | 3.0 kB 00:00
centos-sclo-sclo | 2.9 kB 00:00
epel | 3.2 kB 00:00
nethforge | 4.0 kB 00:00
nethserver-base | 2.9 kB 00:00
nethserver-updates | 4.1 kB 00:00
(1/14): ce-base/7/x86_64/group_gz | 166 kB 00:00
(2/14): centos-sclo-sclo/x86_64/primary_db | 242 kB 00:00
(3/14): ce-extras/7/x86_64/primary_db | 154 kB 00:00
(4/14): epel/x86_64/group_gz | 88 kB 00:00
(5/14): ce-updates/7/x86_64/primary_db | 1.3 MB 00:01
(6/14): nethforge/7/x86_64/group_gz | 1.1 kB 00:00
(7/14): nethforge/7/x86_64/primary_db | 17 kB 00:00
(8/14): nethserver-base/7/x86_64/primary_db | 292 kB 00:00
(9/14): nethserver-updates/7/x86_64/group_gz | 20 kB 00:00
(10/14): epel/x86_64/primary | 3.6 MB 00:02
(11/14): epel/x86_64/updateinfo | 935 kB 00:02
(12/14): nethserver-updates/7/x86_64/primary_db | 94 kB 00:00
(13/14): centos-sclo-rh/x86_64/primary_db | 3.6 MB 00:04
(14/14): ce-base/7/x86_64/primary_db | 6.0 MB 00:05
epel 12738/12738
No packages marked for update
[root@mail ~]#
Thank you Davide!
I already did it.
Hi all!
cc: @stephdl ; @giacomo
Just installed the following updates.
Where I should find nethserver-mail-quarantine settings?
Is this module available for NS 7.6.1810 beta? (Ref: Rspamd quarantine feature )
TIA,
Gabriel
Dec 07 18:56:08 Updated: nethserver-base-3.6.1-1.ns7.noarch
Dec 07 18:56:09 Updated: nethserver-mail-common-2.4.1-1.ns7.noarch
Dec 07 18:56:09 Updated: nethserver-mail-filter-2.4.1-1.ns7.noarch
Dec 07 18:56:10 Updated: nethserver-sssd-1.4.6-1.ns7.noarch
Dec 07 18:56:10 Updated: nethserver-subscription-3.2.1-1.ns7.noarch
Dec 07 18:56:11 Updated: nethserver-release-7-10.ns7.noarch
Dec 07 18:56:11 Updated: nethserver-nethforge-release-7-3.ns7.noarch
Dec 07 18:56:12 Updated: nethserver-subscription-ui-3.2.1-1.ns7.noarch
Dec 07 18:56:13 Updated: nethserver-mail-server-2.4.1-1.ns7.noarch
Dec 07 18:56:13 Updated: nethserver-directory-3.3.2-1.ns7.noarch
Dec 07 18:56:13 Updated: nethserver-mail-p3scan-2.4.1-1.ns7.noarch
Dec 07 18:56:14 Updated: nethserver-mail-quarantine-2.4.1-1.ns7.noarch
Dec 07 18:56:14 Updated: nethserver-mail-disclaimer-2.4.1-1.ns7.noarch
Dec 07 18:56:15 Updated: nethserver-mail-smarthost-2.4.1-1.ns7.noarch
Dec 07 18:56:39 Updated: nethserver-fail2ban-1.1.2-1.ns7.noarch
in the documentation, http://docs.nethserver.org/en/v7/mail.html#quarantine-beta
actually just command line option
Thank you Stephane!
Now, I will wait for the first email notification!
Kind regards,
Gabriel
You will see it will be really interesting ![]()
Ooo! I know that! I already use it with NS 7.5!
Hello!
Just for info, same message.
Gabriel
Hello!
It works as we expected!
Gabriel
