I have installed nethserver 7.5 on my computer then I downloaded all the packages and then I made it to run all in the service. The problem is when my access to ip nethserver is so heavy that ip can not open?
Hi @BimoSora,
welcome to NethServer Community!
Did you install NethServer in a virtual machine?
http://docs.nethserver.org/en/v7/installation.html
Did you install all modules from Software Center?
The better approach would be to install what you really want to test in a first step as some modules may need much RAM.
ram is 8gb but ip open is always slow when empty space ram still a lot
