Hi Guys.
We are testing the NethServer solution, it looks amazing what you guys have done so far !
The issue we are facing off is a little be tricky
On our lab we have:
DELL Server R720 RAID
As a main OS we run vSphere ESXi 6.5
Nethserver runs as a virtual machine.
Server is connected to a MikroTik Routerboard on Port ethernet1 (Server) From ether2 (MikroTik RB)
The problem is, we kinda need to set the NethServer as a Transparent Proxy SSL so we won’t have to install CA to any clients, our lab has 5 Laptops for test purposes.
Ever since NS 7 got out I’ve reading about squid peak and splice solution so you won’t need to get to install any CA to Costumer Browser.
What we need to accomplish is:
Get to work NethServer 7.4 with our MikroTik I’m aware we need tu setup rules on MikroTik in order to NAT or redirect all traffic from NS7 to Test Laptops.
So, if you guys can give a straight example of the NS7 running wiht MikroTik I’d appreciate it
Thanks in advanced
Michael
