Hello,
I set up the message forwarding for pippo@pluto.local to paperino@pluto.local. Everything works properly. Instead the e-mails coming from the POP3 Connector (pippo@ltd.com, set as additional address) for pippo@pluto.local are not forwarded to paparino@pluto.local but only delivered to the pippo@pluto.local box.
I hope I explained myself
I think that’s happen because pop3 connector (getmail) pushes the downloaded mail directly in the INBOX folder.
I haven’t tried this howto with a configuration like yours but you try it:
You can safely ignore the last part where you have to modify the db (unless you have to manage groups too).
After you create the template-custom, remember to go in the pop3 connector dashboard, disable and reenable one (one is sufficient) of the pop3 connector that you have created to activate the template-custom.
