Samba upstream package does not provide the DC role, by now.
@giacomo and @mark_nl already answered, I just want to add: Samba itself suggests keeping the file server / domain controller roles on separate servers.
Whilst the Domain Controller seems capable of running as a full file server, it is suggested that organisations run a distinct file server to allow upgrades of each without disrupting the other
Moreover, I must admit it simplified a lot the configuration both on the file server side (the “host” machine) and the domain controller side (the “guest” machine/container).
So I’m sure an additional IP address is a small price to pay for having them both on NS7
Your question was not stupid at all. I want to say thank you@GG_jr for sharing your experience: your feedback is very important for developers and I’m sure it will be very useful to those who endeavor NS7 testing
You know this is not supported on ns6 neither it is planned on ns7. However I hope it can be implemented easily with SSSD, with OpenLDAP backend. I tried it with AD, but realmd seems supporting the join to a single domain only.
Those run-time thingy thingies still are in the hart of nethserver, probably the heritage of SME.
systemctl reboot/poweroff should take care of that, why can it not be trusted?
Only the Expert policy has more than 10 rules enabled, it seems the rule policy still need some tweaking, I know we’ve talked about this before when I was trying ips in v6.7.
I can’t test snort at all really until I can get snort running with Expert policy per my previous post.
May 23 11:34:03 server88 /sbin/e-smith/db[2666]: /var/lib/nethserver/db/configuration: OLD pulledpork=configuration|Policy|connectivity
May 23 11:34:03 server88 /sbin/e-smith/db[2666]: /var/lib/nethserver/db/configuration: NEW pulledpork=configuration|Policy|expert
May 23 11:34:23 server88 esmith::event[2669]: Rule Stats...
May 23 11:34:23 server88 esmith::event[2669]: #011New:-------27256
May 23 11:34:23 server88 esmith::event[2669]: #011Deleted:---0
May 23 11:34:23 server88 esmith::event[2669]: #011Enabled Rules:----20467
May 23 11:34:23 server88 esmith::event[2669]: #011Dropped Rules:----0
May 23 11:34:23 server88 esmith::event[2669]: #011Disabled Rules:---6789
May 23 11:34:23 server88 esmith::event[2669]: #011Total Rules:------27256
May 23 11:56:45 server88 /sbin/e-smith/db[3246]: /var/lib/nethserver/db/configuration: OLD pulledpork=configuration|Policy|expert
May 23 11:56:45 server88 /sbin/e-smith/db[3246]: /var/lib/nethserver/db/configuration: NEW pulledpork=configuration|Policy|security
May 23 11:56:59 server88 esmith::event[3249]: Rule Stats...
May 23 11:56:59 server88 esmith::event[3249]: #011New:-------0
May 23 11:56:59 server88 esmith::event[3249]: #011Deleted:---0
May 23 11:56:59 server88 esmith::event[3249]: #011Enabled Rules:----8
May 23 11:56:59 server88 esmith::event[3249]: #011Dropped Rules:----906
May 23 11:56:59 server88 esmith::event[3249]: #011Disabled Rules:---26342
May 23 11:56:59 server88 esmith::event[3249]: #011Total Rules:------27256
May 23 12:10:50 server88 /sbin/e-smith/db[3878]: /var/lib/nethserver/db/configuration: OLD pulledpork=configuration|Policy|security
May 23 12:10:50 server88 /sbin/e-smith/db[3878]: /var/lib/nethserver/db/configuration: NEW pulledpork=configuration|Policy|balanced
May 23 12:11:03 server88 esmith::event[3881]: Rule Stats...
May 23 12:11:03 server88 esmith::event[3881]: #011New:-------0
May 23 12:11:03 server88 esmith::event[3881]: #011Deleted:---0
May 23 12:11:03 server88 esmith::event[3881]: #011Enabled Rules:----10
May 23 12:11:03 server88 esmith::event[3881]: #011Dropped Rules:----785
May 23 12:11:03 server88 esmith::event[3881]: #011Disabled Rules:---26461
May 23 12:11:03 server88 esmith::event[3881]: #011Total Rules:------27256
May 23 12:12:34 server88 /sbin/e-smith/db[4403]: /var/lib/nethserver/db/configuration: OLD pulledpork=configuration|Policy|balanced
May 23 12:12:34 server88 /sbin/e-smith/db[4403]: /var/lib/nethserver/db/configuration: NEW pulledpork=configuration|Policy|connectivity
May 23 12:12:47 server88 esmith::event[4406]: Rule Stats...
May 23 12:12:47 server88 esmith::event[4406]: #011New:-------0
May 23 12:12:47 server88 esmith::event[4406]: #011Deleted:---0
May 23 12:12:47 server88 esmith::event[4406]: #011Enabled Rules:----2
May 23 12:12:47 server88 esmith::event[4406]: #011Dropped Rules:----8
May 23 12:12:47 server88 esmith::event[4406]: #011Disabled Rules:---27246
May 23 12:12:47 server88 esmith::event[4406]: #011Total Rules:------27256
Trusted?
Not a big deal at all, just, what seems an unnecessary delay during reboot, I don’t think any of my v6.7 installs have a delay, I’ve only noticed this on v7, but now I can’t remember about v6.7.
No need for systemctl, simply shutdown at shell shuts the machine down in a couple seconds.
The 90 delay is triggered when using the gui shutdown options.
