NethServer 6.8 ISO Final is coming up
Hi NethServer folks! The 6.8 ISO is ready, this is the last call to check it before the official announcement (@alefattorini are you ready?).
The ISO contents are almost equal to beta1.
Updated
For the moment we have only the .torrent file (490MB - infohash 31069496974EDF30B2B157519183FBD5C3EBD076 - sha1sum f0240695bb0cc3f77775a6b5fd4fec486a549b1c - md5sum de0b62fe51395218423ae93550f1a556).
If everything is OK (@quality_team) , we can upload it to SF (@filippo_carletti).
EDIT Mirrors are synching: please wait for them to complete. synched.
great I’ll be waiting
I noticed NethForge is not added automatically by the 6.7 upgrade process. I’d add it to YUM groups, so it can be selected from the Software Center manually.
No problems on a clean ISO installation, instead.
Does it work for you?
Yes, work fine.
I’ve found an issue during system-init event. It seems some e-smith migrate fragments assume the configuration DB is already initialized.
Jun 14 12:30:49 testdavide1 system-init: [INFO] Starting system-init..
Jun 14 12:30:49 testdavide1 system-init: [INFO] Running action S00initialize-default-databases..
Jun 14 12:30:49 testdavide1 system-init: Creating database hosts and setting defaults
Jun 14 12:30:49 testdavide1 system-init: Warning: Migration of hosts failed fatally: Can't call method "get_all" on an undefined value at /usr/share/perl5/vendor_perl/esmith/templates.pm line 825.
Jun 14 12:30:49 testdavide1 system-init: Creating database routes and setting defaults
Jun 14 12:30:49 testdavide1 system-init: Creating database configuration and setting defaults
Jun 14 12:30:49 testdavide1 system-init: WARNING in /etc/e-smith/db/configuration/migrate//feature2956_ns6: Use of uninitialized value in string eq at /etc/e-smith/db/configuration/migrate//feature2956_ns6 line 21.
Jun 14 12:30:49 testdavide1 system-init: ERROR in /etc/e-smith/db/configuration/migrate//issue3289: Program fragment delivered error <> at template line 1
Jun 14 12:30:49 testdavide1 system-init: ERROR: Template processing failed for /: 1 fragment generated warnings, 1 fragment generated errors
Jun 14 12:30:49 testdavide1 system-init:  at /usr/share/perl5/vendor_perl/esmith/DB.pm line 459
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD OrganizationContact=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW OrganizationContact=configuration|City|Hometown|Company|Example Org|CountryCode||Department|Main|PhoneNumber|575-1685|State||Street|123 Main Street
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD PasswordSet=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW PasswordSet=no
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD smartd=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW smartd=service|status|enabled
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD postfix=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW postfix=service|status|enabled
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD phone-home=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW phone-home=configuration|status|enabled|uuid|
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD messagebus=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW messagebus=service|status|enabled
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD ntpd=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW ntpd=service|NTPServer|pool.ntp.org|SyncToHWClockSupported|yes|UDPPort|123|access|private|status|enabled
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD rsyslog=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW rsyslog=service|LogAll2VT6|no|status|enabled
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD pki=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW pki=configuration|CertificateDuration|3650|ChainFile||CommonName||CountryCode||CrtFile||EmailAddress||KeyFile||Locality||Organization||OrganizationalUnitName||State||SubjectAltName|
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD php=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW php=configuration|AllowUrlFopen|1|DateTimezone|UTC|ExposePhp|0|MaxExecutionTime|30|MemoryLimit|32|PostMaxSize|8|ShortOpenTag|0|UploadMaxFilesize|2
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD passwordstrength=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW passwordstrength=configuration|MaxPassAge|180|MinPassAge|0|PassExpires|yes|PassWarning|7|Users|strong
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD lsm=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW lsm=service|status|enabled
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD logrotate=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW logrotate=configuration|Compression|disabled|Rotate|weekly|Times|4
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD shorewall=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW shorewall=service|status|enabled
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD TimeZone=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW TimeZone=Greenwich
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD MinUid=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW MinUid=5000
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD UnsavedChanges=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW UnsavedChanges=no
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD sshd=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW sshd=service|LoginGraceTime|2m|MaxAuthTries|6|PasswordAuthentication|yes|PermitRootLogin|yes|Protocol|2|TCPPort|22|UsePAM|yes|access|public|status|enabled
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD crond=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW crond=service|status|enabled
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD maxGroupNameLength=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW maxGroupNameLength=31
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD SystemMode=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW SystemMode=serveronly
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD sysconfig=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW sysconfig=configuration|Copyright||DefaultLanguage|en_US.utf8|ProductName|NethServer|Release||Version|
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD fstab=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW fstab=configuration
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD httpd-admin=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW httpd-admin=service|ForcedLoginModule||SSL|enabled|TCPPort|980|access|public|colors||favicon|favicon.png|logo||status|enabled
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD nsswitch=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW nsswitch=configuration|aliases|files nisplus|automount|files nisplus|bootparams|nisplus [NOTFOUND=return] files|ethers|files|group|files|hosts|files dns|netgroup|nisplus|netmasks|files|networks|files|passwd|files|protocols|files|publickey|nisplus|rpc|files|services|files|shadow|files
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD root=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW root=configuration|EmailAddress||FirstName||KeepMessageCopy|yes|LastName|
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD maxAcctNameLength=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW maxAcctNameLength=31
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD firewall=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW firewall=configuration|CheckIP|8.8.8.8,208.67.222.222|ExternalPing|enabled|HairpinNat|disabled|InterfaceRoleList|green,red,blue,orange|MACValidation|disabled|MACValidationPolicy|drop|MaxNumberPacketLoss|5|MaxPercentPacketLoss|10|NotifyWan|disabled|NotifyWanFrom|root@localhost|NotifyWanTo|root@localhost|PingInterval|5|Policy|permissive|WanMode|balance|nfqueue|disabled|tc|Simple
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD dns=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW dns=configuration|NameServers|8.8.4.4,8.8.8.8
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: OLD sysconfig=configuration|Copyright||DefaultLanguage|en_US.utf8|ProductName|NethServer|Release||Version|
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/configuration: NEW sysconfig=configuration|Copyright||DefaultLanguage|en_US.utf8|ProductName|NethServer|Release|Final|Version|6.8
Jun 14 12:30:49 testdavide1 system-init: Creating database fwservices and setting defaults
Jun 14 12:30:49 testdavide1 system-init: Creating database tc and setting defaults
Jun 14 12:30:49 testdavide1 system-init: ERROR in /etc/e-smith/db/tc/migrate//issue2809: Program fragment delivered error <> at template line 1
Jun 14 12:30:49 testdavide1 system-init: ERROR: Template processing failed for /: 1 fragment generated errors
Jun 14 12:30:49 testdavide1 system-init: Creating database fwrules and setting defaults
Jun 14 12:30:49 testdavide1 system-init: Creating database networks and setting defaults
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/networks: OLD ppp0=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S00initialize-default-databases[1630]: /var/lib/nethserver/db/networks: NEW ppp0=xdsl-disabled|AuthType|auto|Password||name|PPPoE|provider|xDSL provider|role|red|user|
Jun 14 12:30:49 testdavide1 system-init: Creating database portforward and setting defaults
Jun 14 12:30:49 testdavide1 system-init: [INFO] Running action S20enable-firstconfigwizard..
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1634]: /var/lib/nethserver/db/configuration: OLD httpd-admin=service|ForcedLoginModule||SSL|enabled|TCPPort|980|access|public|colors||favicon|favicon.png|logo||status|enabled
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1634]: /var/lib/nethserver/db/configuration: NEW httpd-admin=service|ForcedLoginModule|FirstConfigWiz|SSL|enabled|TCPPort|980|access|public|colors||favicon|favicon.png|logo||status|enabled
Jun 14 12:30:49 testdavide1 system-init: [INFO] Running action S50nethserver-base-initialize-db..
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1640]: /var/lib/nethserver/db/configuration: OLD dns=configuration|NameServers|8.8.4.4,8.8.8.8
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1640]: /var/lib/nethserver/db/configuration: NEW dns=configuration|NameServers|8.8.8.8
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1641]: /var/lib/nethserver/db/configuration: OLD SystemName=(undefined)
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1641]: /var/lib/nethserver/db/configuration: NEW SystemName=localhost
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1642]: /var/lib/nethserver/db/configuration: OLD DomainName=(undefined)
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1642]: /var/lib/nethserver/db/configuration: NEW DomainName=localdomain
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S50nethserver-base-initialize-db[1638]: /var/lib/nethserver/db/networks: OLD eth0=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S50nethserver-base-initialize-db[1638]: /var/lib/nethserver/db/networks: NEW eth0=ethernet|hwaddr|52:54:00:ff:e8:57|role|
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S50nethserver-base-initialize-db[1638]: /var/lib/nethserver/db/networks: OLD eth1=(undefined)
Jun 14 12:30:49 testdavide1 /etc/e-smith/events/system-init/S50nethserver-base-initialize-db[1638]: /var/lib/nethserver/db/networks: NEW eth1=ethernet|hwaddr|52:54:00:85:a3:4d|role|
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1689]: /var/lib/nethserver/db/networks: OLD eth0=ethernet|hwaddr|52:54:00:ff:e8:57|role|
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1689]: /var/lib/nethserver/db/networks: NEW eth0=ethernet
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1689]: /var/lib/nethserver/db/networks: NEW eth0=ethernet|bootproto|dhcp
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1689]: /var/lib/nethserver/db/networks: OLD eth0=ethernet|bootproto|dhcp
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1689]: /var/lib/nethserver/db/networks: NEW eth0=ethernet|bootproto|dhcp|device|eth0
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1689]: /var/lib/nethserver/db/networks: OLD eth0=ethernet|bootproto|dhcp|device|eth0
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1689]: /var/lib/nethserver/db/networks: NEW eth0=ethernet|bootproto|dhcp|device|eth0|hwaddr|52:54:00:FF:E8:57
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1689]: /var/lib/nethserver/db/networks: OLD eth0=ethernet|bootproto|dhcp|device|eth0|hwaddr|52:54:00:FF:E8:57
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1689]: /var/lib/nethserver/db/networks: NEW eth0=ethernet|bootproto|dhcp|device|eth0|hwaddr|52:54:00:FF:E8:57|onboot|yes
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1691]: /var/lib/nethserver/db/networks: OLD eth0=ethernet|bootproto|dhcp|device|eth0|hwaddr|52:54:00:FF:E8:57|onboot|yes
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1691]: /var/lib/nethserver/db/networks: NEW eth0=ethernet|bootproto|none|device|eth0|hwaddr|52:54:00:FF:E8:57|onboot|yes
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1691]: /var/lib/nethserver/db/networks: OLD eth0=ethernet|bootproto|none|device|eth0|hwaddr|52:54:00:FF:E8:57|onboot|yes
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1691]: /var/lib/nethserver/db/networks: NEW eth0=ethernet|bootproto|none|device|eth0|gateway|192.168.5.253|hwaddr|52:54:00:FF:E8:57|onboot|yes
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1691]: /var/lib/nethserver/db/networks: OLD eth0=ethernet|bootproto|none|device|eth0|gateway|192.168.5.253|hwaddr|52:54:00:FF:E8:57|onboot|yes
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1691]: /var/lib/nethserver/db/networks: NEW eth0=ethernet|bootproto|none|device|eth0|gateway|192.168.5.253|hwaddr|52:54:00:FF:E8:57|ipaddr|192.168.5.111|onboot|yes
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1691]: /var/lib/nethserver/db/networks: OLD eth0=ethernet|bootproto|none|device|eth0|gateway|192.168.5.253|hwaddr|52:54:00:FF:E8:57|ipaddr|192.168.5.111|onboot|yes
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1691]: /var/lib/nethserver/db/networks: NEW eth0=ethernet|bootproto|none|device|eth0|gateway|192.168.5.253|hwaddr|52:54:00:FF:E8:57|ipaddr|192.168.5.111|netmask|255.255.255.0|onboot|yes
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1692]: /var/lib/nethserver/db/networks: OLD eth0=ethernet|bootproto|none|device|eth0|gateway|192.168.5.253|hwaddr|52:54:00:FF:E8:57|ipaddr|192.168.5.111|netmask|255.255.255.0|onboot|yes
Jun 14 12:30:49 testdavide1 /sbin/e-smith/db[1692]: /var/lib/nethserver/db/networks: NEW eth0=ethernet|bootproto|none|device|eth0|gateway|192.168.5.253|hwaddr|52:54:00:FF:E8:57|ipaddr|192.168.5.111|netmask|255.255.255.0|onboot|yes|role|green
Jun 14 12:30:49 testdavide1 system-init: [INFO] Running action S55nethserver-generate-certificate..
Jun 14 12:30:50 testdavide1 system-init: [INFO] Running action S60init-repo..
Jun 14 12:30:50 testdavide1 eorepo[1704]: Repository base (CentOS-6 - Base) has been disabled.
Jun 14 12:30:50 testdavide1 eorepo[1704]: Repository extras (CentOS-6 - Extras) has been disabled.
Jun 14 12:30:50 testdavide1 eorepo[1704]: Repository updates (CentOS-6 - Updates) has been disabled.
Jun 14 12:30:50 testdavide1 system-init: Repository base (CentOS-6 - Base) has been disabled.
Jun 14 12:30:50 testdavide1 system-init: Repository extras (CentOS-6 - Extras) has been disabled.
Jun 14 12:30:50 testdavide1 system-init: Repository updates (CentOS-6 - Updates) has been disabled.
Jun 14 12:30:50 testdavide1 system-init: [INFO] Running action S70nethserver-duc-index..
Jun 14 12:30:51 testdavide1 system-init: Indexed 55502 files and 7454 directories, (919.5MB total) in 0.82 secs.
Jun 14 12:30:51 testdavide1 system-init: [INFO] Running action S90system-adjust..
I see the same errors, but I think that it’s only cosmetic, right?
I didn’t investigate but you may be right! Anyway I won’t release a system with dirty logs…
I agree, the error is cosmetic and it’s related to an old issue.
We can remove it very easily, but I don’t see any problem releasing the issue with a little dirty log :wink:
…because “grep ERROR” or “grep FAIL” would match and might confuse support people :grinning:
/cc @alefattorini @nrauso
If I remember correctly, the upgrade to NS 6,6 to 6,7 was automatic.
This time, a manual upgrade will be required?
And when the maintream 6.8 was out, few days later, I saw a big update in the Sorftware Center… It was not the 6.8 !?!
I’m a bit confused now :confounded:
Updates go on as usual, nothing changes. The transition from 6.7 to 6.8 is one click far. Just press the update button when 6.8 will be released.
Those were the updates from centos 6.8. Now we’re releasing our tiny set of ns6 packages and toasting a new ISO.
I change the title… With ISO :wink:
Good catch Jim! Thanks for clarifying!
I thinked the additional word “Final” should suggest by itself we’re talking about an ISO
I’ve fixed the bug on nethserver-firewall-base and nethserver-httpd-admin migration fragments. The fix was trivial:
http://dev.nethserver.org/issues/3407
The new ISO is ready. I’ve uploaded a new .torrent file on the same URL of the previous. If you already downloaded the previous ISO, no problem: the bug does not affect the running system. For any doubt, check the ISO hashes on the opening post of this thread.
@alefattorini is announcing the release on Monday
Softpedia has already found it:
