Manual updated: http://docs.nethserver.org/en/v6.7/release_notes.html
i’ve added transmission to my mirror, so i can leave the rc1 in seeding with a good bandwidth… just to be ready for 6.7 release ![]()
i haven’t much time… just a rapid interactive installation test
on a VM KVM (proxmox, virtio drv)
during install error on shorewall:
in /var/log/boot.log
Starting shorewall: ERROR: Shorewall startup is disabled. To enable startup, set STARTUP_ENABLED=Yes in /etc/shorewall/shorewall.conf
e[60G[e[0;31mFAILEDe[0;39m]
some warnings
Sep 30 10:18:02 localhost system-init: [INFO] Starting system-init..
Sep 30 10:18:02 localhost system-init: [INFO] Running action S00initialize-default-databases..
Sep 30 10:18:03 localhost system-init: Creating database networks and setting defaults
Sep 30 10:18:03 localhost system-init: Warning: Migration of networks failed fatally: Can't call method "get_all" on an undefined va
Sep 30 10:18:03 localhost system-init: Creating database hosts and setting defaults
Sep 30 10:18:03 localhost system-init: Warning: Migration of hosts failed fatally: Can't call method "get_all" on an undefined value
Sep 30 10:18:03 localhost system-init: Creating database portforward and setting defaults
Sep 30 10:18:03 localhost system-init: Warning: Migration of portforward failed fatally: Can't call method "get_all" on an undefined
post install
redirect from http: OK
Help inline during wizard: ok
Software Center: updates needed:
44 centos updates (if needed i saved the list)
update: ok no fail no error in log
reboot
no more error from shorewall during boot
vpn install:
installed password policies - ok
in /var/log/message
Sep 30 13:29:56 neth67rc1 esmith::event[12966]: slapd start/running, process 12976
Sep 30 13:29:56 neth67rc1 nslcd[12987]: version 0.7.5 starting
Sep 30 13:29:56 neth67rc1 nslcd[12987]: accepting connections
Sep 30 13:29:56 neth67rc1 esmith::event[12966]: Action: /etc/e-smith/events/nethserver-directory-update/S10nethserver-directory-conf SUCCESS [3.375728]
Sep 30 13:29:56 neth67rc1 nslcd[12987]: [8b4567] ldap_result() failed: No such object
Sep 30 13:29:56 neth67rc1 nslcd[12987]: [7b23c6] ldap_result() failed: No such object
Sep 30 13:29:56 neth67rc1 nslcd[12987]: [3c9869] ldap_result() failed: No such object
Sep 30 13:29:56 neth67rc1 nslcd[12987]: [334873] ldap_result() failed: No such object
Sep 30 13:29:56 neth67rc1 esmith::event[12966]: Action: /etc/e-smith/events/nethserver-directory-update/S11nethserver-directory-dit-setup SUCCESS [0.316997]
Sep 30 13:29:56 neth67rc1 esmith::event[12966]: Action: /etc/e-smith/events/nethserver-directory-update/S50nethserver-directory-password-policy SUCCESS [0.056794]
and
Sep 30 13:30:21 neth67rc1 esmith::event[13494]: lsm stop/pre-start, process 13754
Sep 30 13:30:22 neth67rc1 openvpn[13836]: Options error: Unrecognized option or missing parameter(s) in host-to-net.conf:13: server (2.3.7)
Sep 30 13:30:22 neth67rc1 openvpn[13836]: Use --help for more information.
Sep 30 13:30:22 neth67rc1 esmith::event[13494]: Starting openvpn: [FAILED]#015
Sep 30 13:30:22 neth67rc1 esmith::event[13494]: Stopping xl2tpd: [FAILED]#015
Sep 30 13:30:22 neth67rc1 esmith::event[13494]: Action: /etc/e-smith/events/runlevel-adjust/S20runlevel-adjust SUCCESS [1.408648]
Configure a basic vpn server for roadwarrior (connection not tested):
all ok on log
reboot
install monitoring group from webUI
no log error/fail
from Dashboard>Applications
login to OCS and Adagios with admin account ok
more tests in the next days…
Installed today
Installation worked great with no issues.
Selected only English and Only English was installed.
After finished, and with first login, i’ve run yum update from the cli.
Wizard looks great (still think, server function should be added there
and add the packages prior to finish)
5.Dashboard looks great, worked without any setup, don’t understand why so
many messages, might be because i updated after install?
- Log viewer, ok, empty, follow, read, no issues.
7.Software center seems ok,
7.1 Package install selected almost every group and installed no
issues.
8.Security, Network Services, SSH, trusted networks, everything ok
9.Configuration, everything ok.
I’ll start checking applications tomorrow.
Downloading
What do you mean? The possibility to choose between a server-only or a gateway configuration?
I think he means something like that:
@davidep I love NethServer.
The help files are already on GitHub? attached modules that are not translated yet or if incorporated in transifex.
Regards!
Thank for your warning!
We’re fixing the Software Center and Restore Data page.
About the Help file. I can’t see NethServer_Module_RestoreData.rst under
Could you create a PR with it?
No problem, I will create today
Server-only, gateway, ad/samba, mail, web server, something like for
starters that shouldn’t have to think on what packages to choose for that
function.
Ok, got it! You’re right, this is a wished feature but it requires much much work and we don’t have the time neither resources to do it right now. Sorry ![]()
I have a fix for this problem, anyone want to test it?
I LOVE this discussion and this “TEAM TEAM TEAM TEAM… I even love saying the word TEAM” (quote)
The fake nethserver-firewall-base-ui is available for 6.6? I don’t see it listed, even after a yum update.
I’m not going to assign that issue to myself because I may be doing things completely wrong. ![]()
However, I ran this on a clean install of 6.6:
yum --enablerepo=nethserver-testing install nethserver-firewall-base --nogpgcheck
It appears to be working fine. Any comments or suggestions?
Edit: ran the following command on another clean install where I had installed firewall and dns/dhcp from the software center prior:
yum --enablerepo=nethserver-testing upgrade nethserver-firewall-base --nogpgcheck
Everything is working great on this one too… Did I do any of this correctly? LOL ![]()
I can see the package is in nethserver-testing/6.6 repo:
Try the command
yum --enablerepo=nethserver-testing update nethserver-firewall-base-2.7.2-1.1.gf6e3b28.ns6
The Software Center page can’t see nethserver-testing
I just checked: the warnings are ugly but also not harmful ![]()
Why there’s no announce on Distrowatch?
It could bring lot of testers and feedback…
