This is strange,
the hardware support is quite wide
Do you have any error at boot?
Is the USB stick you’re using for NethSecurity the same used for Ubuntu? (I just want to exclude a USB stick problem as happened to me a couple of times)
Also, you can search if someone else is using your hardware using this form: Hardware
It’s not booting.
The bios of the Atom 330 sees the Cruzer stick and it sees the hard drive I wrote Nethsecurity too as well, it just won’t boot to them.
I don’t see the any Atoms in the hardware list for openwrt. It’s likely all my old hardware is too old and everything else I have is in use.
Is there a recommended multiport mini pc without wifi for Nethsecurity, like a Protectli or Qotom or …
If you can grab yourself a second hand or new PCengines APU you should be fine off.
I’m using one for OpenWRT, the second box is being prepped for NethSecurity testing.
Different models are available, but I’m using the APU4d4.
Quad Core 1 GHZ AMD SoC
4 GB RAM
4 Intel 1 GBE NICs (Some models have 3).
Low Power consumption, no moving parts (quiet!).
Boots form a 120 GB mSATA SSD (Other sizes can be used) or USB 2/3
As stated in my original post, I did write to and attempt to boot from spinning rust so I have a hd installed to the 330 with the Nsecurity img written to it that the 330 does not see, the bios does see the HD but will not try to boot to it.
I had tested a laptop as well, just to see if it would boot. It would not, but looking through the bios settings for the laptop last night I found it was set to legacy only boot and once I enabled uefi it booted to an opnsense img I wrote to another usb stick, when I tried that opnsense stick in the 330, the 330 wouldn’t see it, and last night I booted the original usb stick with the Nsecurity img in the laptop and am looking at Nsecurity right now on the laptop.
I don’t see any setting in the 330 bios re; uefi.
Is there an edit in the grub cfg I can make or a way of writing the img or any other way I can make a boot disk this 330 can see? I had actually used it for an ngfw for some time before I virtualized the ngfw.
If I can get the 330 to run the network’s firewall I could then free up a host and potentially begin to attempt the NS7 to 8 migration per my other post without buying new hardware.
Would you consider to test the install/image-writing of OpenWRT?
If the behavior is the same, there’s a possibility that the issue comes from the starting project.
I have wasted way too many hours on this. It appears the boards for both of my Atoms; 330 and 510 are bios only and as you can see in the above link openwrt gave up on bios long ago, they do offer legacy images for bios but I’m not looking to run openwrt. We should probably add to the Nsecurity install docs that support is only for eufi.
I have to disagree: current image can correctly handle both UEFI and non-UEFI bios.
We ship machines with non-UEFI bios and it works good.
Also, all the development is done on legacy bios virtual machines.
Sot it seems to me a very specific hardware problem.
Probably, it can be fixed with a dedicated legacy bios image but I’m not sure it worth trying for such old hardware.
