I don’see on GUI the possibility to launch a speedtest as i can do it on previous nethserver7.
Is possibile to do from CLI and if yes, how?
Thanks
Thanks
It’s coming with next milestone I guess: feat(conf): add speedtestcpp package by filippocarletti · Pull Request #962 · NethServer/nethsecurity · GitHub
So for now is not possible also in the cli?
if this is the command, I don’t see an option to test different wans (multiwan) on the same nethsecurity
i don’t know i maybe some devs can answer this problem…waiting for it.
mwan3 use <name of wan> speedtest --force-by-latency-test
And for do a speedtest from CLI in my case this firewall doesn’t have multiwan only one, is possible to do it?
Yes, it will be possible also with just one WAN interface.
If i do this command i receive this output:
root@fw:~# mwan3 use wan1 speedtest --force-by-latency-test
could not find family for wan1. Using ipv4.
Running ‘speedtest --force-by-latency-test’ with DEVICE=eth1 SRCIP=192.168.0.210 FWMARK=0x3f00 FAMILY=ipv4
/usr/sbin/mwan3: line 238: speedtest: not found
It’s not implemented yet, we have to wait until next milestone.
