Hi Andrea
I don’t have much time this week to testing, so i’m asking if you and the other guys on the forum and nethesis team @davidep@giacomo have found which is the best procedure/configuration for install Nethsecurity on Proxmox VE on ZFS Storage?
Perhaps it would also be useful for everyone once the procedure for zfs has been found, to update the official nethsecurity documentation.
I’ve never tried NethSecurity on proxmox. Let’s if @francio87 has some ideas on the issue.
What can I say, it that I develop the system on KVM with an underlying ext4 system and I never had this kind of issue even if the machine has been killed.
So it seems to me really a problem of the virtualization system rather then NethSecurity itself.
At the moment, I can’t upgrade Proxmox to version 8.x to make the test on the new version, however, the creation of the machine and the import process are successful, and it starts up correctly, maybe it’s just an issue of Proxmox 8.x
(The other nodes that I have available do not use ZFS, but rather LVM on hardware RAID controller.)
Well, in the end I did what I usually advise against … I performed an in-place upgrade of Proxmox to version 8.1.10
The old VM started correctly and also created a new one, and this one also had no problem.
Regarding the issues with Proxmox, I don’t have many other ideas. Have you perhaps tried installing it on another node?
The steps you have followed seem correct to me
No but @sarz4fun have done many test with nethsecurity on proxmox ve with zfs, and if i remember correctly he has the same problem i have, and it fix doing attach 2 disk on the vm.
But in your case @francio87 as you written above, you followed the procedure as described on the nethsecurity official documentation, and the vm booted normally…
With ZFS, a common issue is simply a “not quite enough” CPU, RAM issues. But mainly spped issues (timeout issues) due to a low powered CPU / RAM / hardware.
If you say 32 GB RAM, quad core, those are also probably the issues.
And - a quad core on a 3 GHz CPU is a different animal from a 1 GHz CPU.
Take into account IO issues…
Running on NVME will probably have no issues, on SSD or HD you will probably heve issues.
Hi install ProxmoxVE inside Virtualbox and install on ZFS (Raid1) and follow the procedure as described on nethsecurity documentation it boot up at 1st try:
UPDATE
As written in previous post above, i do the command to import disk two times, and so i have two scsi device, scsi0(not boot) and scsi1(boot nethsec correctly), so i procede with detach scsi0 and remove it and then detach scsi1 and re-add as scsi0 device, so this is possible solution for who have the same problem.
Thanks
