Nethsecurity IPSec custom metric route
On Nethsecurity is possible to create a custom metric?
I have 2 links and connect to same ipsec, with 2 ipsec connection create 2 routes and conflict because 2 route have same metric and do not edit
Sorry my bad english.
Thx
Rafael Tavares
Ibinetwork Informática - Brasil
You should be able to set them using uci, inside the /etc/uci/network config file.
See: Testing to determine if you are a bot!
Probably, the UI will override them if you change something on the IPSec tunnels
Thanks, i try and returno with result.
I’m active 2 ipsec again and ok, dont need to modify nothing.
thx
