Hello,
I flashed NethSecurity to a 80gb disk.
After flash, in ui, i can mount unused space as external log disk.
I mounted the partiton, all run as exceped.
I deleted the partition from the ui.
I can not see the partiton anymore.
Can i mount the remaining space of disk again?
Than you.
It’s a known bug being fixed after beta 2.
Until the next version release, you could temporarily use parted /dev/sda rm 3
to reclaim the unused space.
