In a Test environment on a hardware based NethSecurity 8 box, I have 3 NICs. LAN and WAN are used.
I wanted to create a second LAN Zone (LAN2) but typed DMZ as a typo.
Now I can’t remove the DMZ - and it’s now a "Yellow / Orange network.
It seems certain “Zone Names” are hardcoded, and can not be modified, even if no NICs are allocated or any rules ever created.
Is this the case?
(Confirmed, but incorrect docu, as “case sensitive” is not valid.).
I can add other Zones, these all become automatically “blue” networks.
Is the color coding also hardcoded and can not be changed?
I find this VERY confusing, and I’m NOT a firewall beginner!!!
I have reported on my experience with NethSecurity 8 in a Testimonial, this is to confirm certain findings with this “strange” behaviour…
Additionally, if I need a second DMZ (eg DMZ2) this becomes a blue network?
And there’s no visible option to change the color allocations.
The same goes if I need a second LAN, eg LAN2. This does NOT become a GREEN LAN, but also a BLUE network.
It’s probably possible to change parts or all of the above via CLI - but please - where is ANY of this documentated?
The latest documentation here:
https://docs.nethsecurity.org/en/latest/zones_and_policies.html
is not really correct, see the information about “case sensitive”.
I used Capitals, yet my DMZ can not be modified, nor removed.
It seems that only one zone “DMZ” is allowed - and is no more removeable, even when created in error without ANY use…
Is this considered “Easy to use” ???
And here’s another post with a user confused by the network “bridging” NethSecurity does at setup - something that did NOT happen in NethSecurity7 (NS7)…
→ The idea that an “easy to use firewall”, “suitable for beginners” needs CLI to remove an unused Zone as a result of a simple typo is a bit REALLY far fetched in my opinion! ![]()
